whats the difference between 205 60 and 205 65 tires?
Old 01-20-08, 12:01 PM
phild
phild's Avatar
Default whats the difference between 205 60 and 205 65 tires?
i was going to buy the 205 60 tires to replace the 65s. is this possible? its a 92 es 300. what are the negatives of doing this?
Old 01-20-08, 12:14 PM
Sash
Sash's Avatar
The're thinner.
Old 01-20-08, 01:39 PM
lxtauto
lxtauto's Avatar
Trere are higher tires. not good
Old 01-20-08, 02:15 PM
phild
phild's Avatar
ok thanks a lot
Old 01-20-08, 03:06 PM
19psi
19psi's Avatar
a 205 60 is going to be a bit shorter in overall height than the 205 65. this will give you a smaller sidewall, not by much. it will put more tread on the road and increase your steering response.
Old 01-20-08, 08:14 PM
llcoolpass
llcoolpass's Avatar
one other , major, important point: the 205/60 R15 will have [apples 4 apples] less load capacity.... so even if you don't over load it, you will need to use some more PSI in that tire...
Tom-GV
02-22-10 08:02 PM
TruPlaya26
09-12-06 01:05 PM
gcrim21
Wheels, Tires & Brakes Forum
09-23-04 06:48 AM
lexi2004
07-30-04 01:09 AM
Bahadur
01-21-04 11:04 PM
Quick Reply: whats the difference between 205 60 and 205 65 tires?
