ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Where is the AFS off switch?
Old 01-10-08, 09:41 AM
frmsuv2van
frmsuv2van's Avatar
Question Where is the AFS off switch?
In the 2008 ES350 owner manual, there is a picture of an AFS OFF switch (to turn off the Adaptive Front Lighting system) which is located at the knee dash area above your right knee (on the right side of the steering column). However, the switch is not there when I look for it in my car which has the AFS w/ HID lamp option.
Old 01-10-08, 10:24 AM
LexBob2
LexBob2's Avatar
The switch is up underneath the dash, to the right of the steering column and the amber LED light for the footwell. It's best to stick your head under the dash to see it. Good luck.
Old 01-10-08, 08:18 PM
amf1932
amf1932's Avatar
Here it is:
Old 01-11-08, 10:45 AM
frmsuv2van
frmsuv2van's Avatar
Thank you!....I found it.
The manual has the picture that shows the AFS OFF switch at the same level as the trunk release / gas cap switches (but on the other side of the steering column). No wonder I couldn't see them when they are actually hidden below the dash.
Old 01-11-08, 06:58 PM
Macklin
Macklin's Avatar
Why would you want to turn this most useful feature off?
Old 01-15-08, 11:24 AM
frmsuv2van
frmsuv2van's Avatar
No, I don't want to turn AFS off...I just want to know where the button is....
Old 01-29-08, 03:11 AM
ng123ray
ng123ray's Avatar
i wonder how hard it would it be to pop out that foot light and switch it to a white LED bulb.. =?
Old 01-29-08, 07:39 AM
mha63
mha63's Avatar
What is the button right next to the AFS switch. I have not yet figured that out or found in the voluminous manual?
Old 01-29-08, 08:16 AM
amf1932
amf1932's Avatar
Old 03-18-13, 06:17 PM
soberstan
soberstan's Avatar
Guys, thanks for the help. The switch was right where you described, to the right of the steering wheel, just out of sight.
Thanks,
Soberstan
Old 03-25-13, 07:33 AM
HappyJon
HappyJon's Avatar
The other switch is to reset the tire pressure warning light on your dash, should one of your tires loose too much pressure.
Old 12-12-13, 06:09 PM
kalki2020
kalki2020's Avatar
Originally Posted by amf1932
I have it like this.. with my used 2008 ES350. I am assuming I don't have AFS as I don't have the HIDs.
Old 12-13-13, 02:47 PM
ThumperPup
ThumperPup's Avatar
yeah if the buttosn not there and theres not a plug thats missing a connection than safe to say you dont have it also i don/t kknow if you can get afs without hid i don/t think there was the optiion
Old 12-15-13, 08:05 PM
iceblast
iceblast's Avatar
Does anyone recommend turning off the AFS in the extreme cold winter months ? I.e. so there are no moving parts to be broken when the temperature hits -5 F to -22F (-15C to -30C) here in Canada?
Thanks for the help!
Old 12-16-13, 12:58 AM
MikePA
MikePA's Avatar
No. If it were recommended, that'd be in the owner's manual.
Quick Reply: Where is the AFS off switch?
