LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Tire pressure for LX470
Old 12-21-07, 05:28 PM
Norboo
Norboo's Avatar
Default Tire pressure for LX470
What is the correct tire pressure for LX470?
I have Michelin Latitude Tour HP 275/60/18
Thank you
Old 12-21-07, 06:46 PM
AKoch
AKoch's Avatar
It is on the driver's side frame sticker. 32 front, 35 back I believe.
I personally prefer 35 on all four.
Old 12-21-07, 10:15 PM
V8_Fan
V8_Fan's Avatar
I thought it was 29/32 or something like that. Check the sticker in the driver's side door jamb. The pressure is for OEM-sized P-rated radial tires. Note that LT tires require much higher pressures. Regardless, I inflate my stock tires to 32-33psi front/rear. I find I get good fuel economy and even wear at these pressures. Keep in mind that during the winter, you have to inflate often since a sudden drops in temps can cause your tire pressure to really drop. I find I have to check every month as the weather gets colder, but in the spring, as it warms, the pressure increases with temp, so don't have to inflate as often. Pick a day w/ low humidity to inflate. This will result in less moisture inside the tire, less temp fluctuation, and only helps the rubber life as tires degrade internally due to moisture.
Old 12-31-07, 02:12 PM
Max707
Max707's Avatar
I alway ran 36 psi and the tread layed down perfectly
Old 01-01-08, 12:02 PM
wignot
wignot's Avatar
Maybe there is more to this, but shouldn't you just go by what is on the sidewall?
Old 01-02-08, 02:42 PM
psychodoc
psychodoc's Avatar
IMO-the numbers on the door give you the 'smoothest' ride, but running 33-36# all around improves mileage and tires last longer...I add 3-4#s...the sticker recs F29 & R32...I run ~F33 & R35 and this seems to give me the best trade-off...(at least that's what I start out with)...probably leaks down a little every week or 2)...34-35#s all around makes it simple...
Old 01-02-08, 06:27 PM
Max707
Max707's Avatar
remember for every 10 degrees the outside temps go down you lose 1 psi.
IS350SWFL
04-30-15 11:34 PM
tonyscv
HS 250h Model (2010-2012)
01-07-10 10:28 AM
gijoe
LX - 3rd Gen (2008-2021)
11-30-09 10:48 PM
9520G
09-13-06 04:54 PM
electro992
13
05-20-04 10:41 AM
Quick Reply: Tire pressure for LX470
