Tweak tip for auto Sc shifting!
Old Nov 27, 2007 | 04:18 PM
VJZ's Avatar
VJZ
I just did this to my SC300 auto. One will notice that the main TPS is already tilted pretty far to the left, so you can rotate it as far left as possible and you will notice very, very smooth shifts and a wider powerband like OLT said.
Highly recommended.
Great job!
Old Nov 27, 2007 | 04:44 PM
SC_coupe's Avatar
SC_coupe
Just tried this out for myself. Thanks for the tip, no more harsh engagement. I'll have to take it around the block when the roads dry up to see how the transmission behaves.
Old Nov 27, 2007 | 09:45 PM
lxsv8's Avatar
lxsv8
Everyone that has tried this has mentioned that there is no harsh jolt into gear - but how does the car drive overall? Has anyone tried this adustment that has been running a piggyback ECU?
Old Nov 28, 2007 | 08:08 AM
greyBLITZ's Avatar
greyBLITZ
I definitely will give this one a try! I've been pretty annoyed with most of the symptoms that you guys have mentioned, especially the jolt when you first put it into gear. I also hear that there is a way to adjust the transmission throttle cable which may have similar effects, but I'm not sure if it's the same as this, I'll see if I can find the original article.
Old Nov 28, 2007 | 12:35 PM
vwynn's Avatar
vwynn
hmm then what explains those.. CRAZY Jolts that happen once every other week?
like i remember warming up my car.. n then got in to drive. Pop it in reverse holdin on brake. n BAM the car jolts back like.. a big sudden shock.
wierd? or something is bad?
but this mod.. has anyone turned it right?? haha
Old Feb 9, 2008 | 10:07 PM
breakb's Avatar
breakb
really?! smoother shifting! YES!!! haha i hate it when it's going from 1st to 2nd gear and it sorta shifts hard. gonna try it sometime next week. monday or tuesday cuz no work. thanks for the tip.
Peace out
Old Feb 9, 2008 | 11:15 PM
Knightridr's Avatar
Knightridr
i wish my car was out of the body shop. I would try this in a heartbeat. My car also does the jolt from park to reverse. but my gears shift smooth as butter.
Old Feb 10, 2008 | 02:02 AM
rootaku's Avatar
rootaku
Editing my post, seems like my TPS is facing completely to the right just about and I do have hard gear changes, So I'll try this out but, it seems like the wiring is already pulled to its max length as in I don't know how i'm going to move it if the wires won't reach anymore. Guess I'll have to dig around that area a little, I don't wanna tug on it and it pops itself out of somewhere or something >_<?
Old Feb 11, 2008 | 02:25 AM
breakb's Avatar
breakb
ok, so today i tried this. i turned it counter clock wise. still has a jolt everyone once in a while, and it still jolts when it's going from 1st to 2nd. but. my accleration to the foot pedal is much better. except when i gased it on this straight away near my house, it only went up to like 5k rpm. idk if it's a fail safe thing or sumtin, but i'mma tweak with it more tommorrow. move it around a lil more and see what happens.
Peace out
Old Feb 12, 2008 | 01:23 AM
LEXCHILD's Avatar
LEXCHILD
so im not exactly again how to do this...
unscrew tcp, (3 screws) and twist it counter clockwise?
would anyone have detailed pic?
Old Feb 14, 2008 | 12:16 AM
rootaku's Avatar
rootaku
I messed with it a bit more today, I don't think I can move it really much, the wire that connects to it is at its limit and with the 2 screws removed, i could only manage to move it about a quarter of an inch. If the wire was longer I still don't see how I could slowly move it though since I won't be able to lock it back into place unless its ok to have it not screwed back in? Maybe it's just my SC300. Any insight on this? Unless I've been messing with the wrong component <_<.. But I don't think I am.... In the picture I posted above, the thing with the red arrow is indeed the TPS correct? as pictured in O.L.T's initial post.
Old Feb 14, 2008 | 01:24 AM
breakb's Avatar
breakb
yeah it is restricted. but when i did it i noticed my pedal was more sensative. like not as much lag. it did take away some of the jolting from the shifting to like D and R. but i think it might be motor mounts.
Peace out
Old Feb 14, 2008 | 02:02 PM
LEXCHILD's Avatar
LEXCHILD
i will try to take some pictures or a video and see how it goes--- mine is 95 sc400
im sure there is a diffr betweet sc300 and sc400 tps(ie. cable length, moveability, result(s) )
Old Oct 21, 2008 | 01:49 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Now with video
http://www.youtube.com/watch?v=n3-DfW2ouGA
(sorry I have a cold right now so I can't breathe to speak clearly. LOL)
Old Oct 21, 2008 | 02:06 PM
mr2tosc4's Avatar
mr2tosc4
lol was that you? sounded like you got a cold
