OH Platinum VIP Cup kit w/management
I have for sale a set of Platinum VIP Phantom cup kit that I used on my Megan racing LP coilovers for a 2007 LS460 RWD. The cups can be used on any Megan racing, BC Racing coilovers or coilovers with a 12.5 mm shock shaft. Included parts: 4 platinum vip cups. 2 bought brand new installed from platinum vip (included 19 inch leader lines) 2 cups bought used. NOTE: You will have to send the cups along with your coilovers to be installed by Platinum VIP. They charge $250 and will install new seals at the time of Installation. The reason is because they suggest they install the cups on to the coilovers and I am not sure if the seals are damaged or not due to removing them from the coilovers. I will drop the price of the kit $250 because of this.
Also included are:
Accuair switchspeed management with digital touchpad. (Will include additional digital tank pressure sender I bought for a backup).
Accuair vu2 (installed and used a week)
Viair 380c compressor (brand new)
3.5 gallon chrome air tank
SMC water trap All D.O.T approved push to connect fittings as well as brass D.O.T brass fittings (I will also include all the additional PTC fitting and threaded fittings I have. Should have no reason to buy more. Many are brand new).
8 gauge power supply kit along with a Stinger relay.
Dakota digital pressure gauge with 4 senders and tank pressure sender ( I bought this used and I never got around to installing it.)
You will need to buy 1/8 dot air line as well as wiring to wire your grounds and such.
Unlike other cups you can drive with air in the cups and park aired out. You will only want about to raise the car 2-3 inches cause the more air in the cup the higher the spring rate becomes and causeway a very bumpy ride. On my LS460 I couldn't tell much of a difference driving with 1.5-2 inches of air in the cups. I am looking to get $1850 + PayPal fees and shipping. Why am I selling? My family and I are building a new house and will not have a curb for me to worry about. I did drive with this kit with air in the cups during the Ohio summer months. I never had a single issue with the cups, management, or wiring. Only issue I had was with the viair check valve (I kept over tightening it, and as long as you don't tighten it to much you won't have any issues. If you have any questions or want additional pics please text me at 513-623-0773.
See pics in post 2. I will update this thread with more pictures in the morning.
Also included are:
Platinum-VIP
05-14-12 08:23 PM
EXE.UCF10
16
12-26-06 03:49 PM
