MD IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE
Old 09-16-16, 07:29 AM
An2ny
An2ny's Avatar
Default IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE
Lexus IS 250 350 ISF coilovers suspension Intake exhaust brakes pads sway bars LSD differential Subaru BRZ Scion FRS Toyota KW V3 F sport F-Sport OEM Takeda M2 .
All parts were on my 2008 manual Lexus IS250 RWD, but obviously some parts may fit different model & years so please make sure you check or know before buying anything. I prefer local pick up (Maryland), but I may be willing to ship some items.
Let me know if you have any questions or if you would like to see specific pictures.
Takeda Intake
Used about 5K miles
Price: $235
Everything included and perfect working conditions; Takeda claims a max gain of 13hp and 11lbs. x ft. torque. I really doubt that it gives that much power, but it definitely sounds awesome.
Manzo Performance Stainless Steel Cat Back Exhaust M2
Used about 5K miles
Price: $195
Sanded primed and painted Flat Black. It has the normal few scratches on the bottom from pulling up a driveway but it is only cosmetic and you cannot see it once it is on the car; also you could re-touch those spots and it will look perfect again.
SOLD_KW V3 Coilover Suspension
Used about 5K miles
Had these on the car for about 6K miles, the springs have some normal cosmetic surface rust (all KWs I had always do that). I drove the car one winter but never on snow. They are in perfect working conditions. NOTE I will also include all 4 Lexus OEM Complete top hats assembly so you can just install without having to disassemble and use the ones on your car; this is about a $400 in parts included, also saves time and frustrations during the installation.
Fitment:
***KW Suspension Variant 3 Coilovers 35257002 for a 2006 2007 2008 2009 2010 2011 2012 Lexus IS350 ((GSE20/21) RWD Sedan) and 2006 2007 2008 2009 2010 2011 2012 Lexus IS250 ((GSE20/21) RWD Sedan) - Lowers: Front 1.2-2.3/Rear 0.9-2.1 | Springrates: Front 515/Rear 455
These will fit the ISF; I believe the only difference is the higher front spring rates to compensate for the heavier V8
***KW Suspension Variant 3 Coilovers 35257003 for a 2008 2009 2010 2011 2012 Lexus IS-F - Lowers: Front 0.2-1.2/Rear 0.2-1.2 | Springrates: Front 625/Rear 455
F-Sport Front Sway
Used about 4K miles
Price: $175
Perfect working condition and looks great for a used sway bar cosmetically. Includes the F-Sport bushings.
SOLD_F-Sport Rear Sway
Used about 4K miles
SOLD_Lexus IS white Interior OEM LED Package
Used about 4K miles on the car
Putco brand; these are specifically for cars like Lexus that will trigger a CEL with some of the cheap LEDs.
Brake Caliper IS350 upgrade/ BBK 4 Piston Calipers.
Used perfect condition (never installed on my car)
Price: $340
I never got a chance to install them on the car, but they are in great condition and do not need anything.
Lexus IS350 USA Model Performance Brake Rotors (Front) (Brand new in box)
Brand new in box (never installed)
Price: $85
I never got a chance to install them on the car.
IS350 BBK Front Pads Carbotech: CT1118 AX6
Used (never installed on my car)
Price: $110
Used but tons of life left.
2 New Brake Rebuild kit Centric.
Brand new in bag (never installed)
Price: $10
A set of 2 to rebuild the IS350 front calipers. The Brake calipers that I am selling didn’t need it since they are in great conditions, but I got these just in case.
G2 Caliper paint kit Blue shade similar to F-Sport Blue
Brand new in box (never used)
Price: $45
This is a special color that cost more that the regular colors. Never got a chance to install the brakes so didn’t use this kit.
“Lexus” Caliper High Temp Caliper Decals
White-Brand new in box (never used)
Price: $5
I never got a chance to install the brakes so didn’t use this kit.
Scion FRS/ Subaru BRZ OEM Limited Slip Differential (LSD) 4.1 Final Gear
Used less than 3K miles perfect condition (never installed on my car)
Price: $425
This is a Torsen T2 Limited Slip Differential (LSD) with the OEM 4.1 Final Gear. This is the complete pumpkin, you can just bolt this on the IS250. I never got a chance to install it on my car.
1990 Supra MK3 LSD Clutch Type Mk3 Supra rear diff 3.73 Final Gear
Used not sure about miles, but it is in good condition (never installed on my car)
Price: $125
This a clutch type differential and it is the complete pumpkin also, you could install the internals on an IS250. I never got a chance to install it on my car.
Attached Thumbnails IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-1-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-8.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-11.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-5-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-3-.jpeg
IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-12.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-1-2-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-1-4-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-7-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-1-3-.jpeg
IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-4-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-2-1-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-3-1-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-6-1-.jpeg   IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE-image-9-1-.jpeg
An2ny is offline
Old 09-17-16, 08:05 PM
leoferus
leoferus's Avatar
It was a pleasure meeting and doing business with you today. The rear sway bar will be installed tomorrow.
- Ricardo
leoferus is offline
Old 09-19-16, 08:42 AM
An2ny
An2ny's Avatar
- Ricardo
Great buyer
Thanks Ricardo, enjoy the bar!
An2ny is offline
Old 09-19-16, 11:26 PM
Richy21
Richy21's Avatar
Interested in the coils. Did you buy them new?
Richy21 is offline
Old 09-20-16, 11:48 AM
An2ny
An2ny's Avatar
They are pending at the moment.
An2ny is offline
Old 09-21-16, 08:19 AM
Wrauda
Wrauda's Avatar
how much for the Takeda intake ship to 77084?
thanks
Wrauda is offline
Old 09-21-16, 10:56 AM
An2ny
An2ny's Avatar
thanks
PM sent!
An2ny is offline
Old 09-25-16, 06:20 PM
bbaugher47
bbaugher47's Avatar
If youre coming to the lexus meet next month , ill take those caliper stickers off your hands if ya still have em!!
bbaugher47 is offline
Old 09-26-16, 05:45 AM
An2ny
An2ny's Avatar
I could if it is close by...where and where?
An2ny is offline
Old 09-27-16, 03:31 AM
bbaugher47
bbaugher47's Avatar
Lexus of rockville , sunday October 23rd. From 0800-1200
Old 10-04-16, 06:41 AM
An2ny
An2ny's Avatar
Bump! Updated and New lower prices
An2ny is offline
surensm
Performance
16
08-18-15 10:11 PM
FD3SISF
05-04-14 12:59 PM
FD3SISF
05-03-14 08:50 PM
DrivenSoul
Suspension and Brakes
23
01-31-14 10:48 AM
PhiDeltBee
01-02-14 06:20 PM
Quick Reply: MD IS250/350/ISF KWV3, F-sport coilovers, Intake, exhaust, sway bars, LSD & MORE
