OH ISF & ISx50 - part out - OS GIKEN, interior, suspension, S/C, BBK, lots!!
Old 08-16-14, 12:57 PM
rawr2is250
rawr2is250's Avatar
Wish that bumper was SFP
rawr2is250 is offline
Old 08-16-14, 02:07 PM
RMA
RMA's Avatar
That LSD is tempting indeed.
RMA is offline
Old 08-17-14, 06:45 AM
mikellucci
mikellucci's Avatar
Few more small items posted and pics of tails, tires, etc. Thanks!
mikellucci is offline
Old 08-18-14, 08:27 PM
mikellucci
mikellucci's Avatar
PMs replied to! I know someone could use the ISF steering wheel and all the other little items! The OS GIKEN is being overlooked but it'll find a good home soon enough
Old 08-18-14, 08:49 PM
MK4Sup_isF
MK4Sup_isF's Avatar
If only it was in an ISF pumpkin/final drive. I like to cruise 80mph at 2100rpm very much! Good luck bro!!!
MK4Sup_isF is offline
Old 08-19-14, 04:31 PM
Gville350
Gville350's Avatar
^Just swap your FD and pinion into this carrier!
Gville350 is offline
Old 08-21-14, 07:19 AM
redspencer
OG Member
Forum Moderator
redspencer's Avatar
I'm bummed to hear that you've finally decided to part away from your 2IS projects after all the time you've invested with everything. Sometimes you have to do what you have to do! Hopefully you'll still be around the forums to share in your wisdom of 2IS knowledge from everything you have previously learned (especially when it comes to IS350 and IS-F wiring, hehe).
redspencer is offline
Old 08-23-14, 03:58 PM
mikellucci
mikellucci's Avatar
^ Thanks!
Bump there's still some good stuff left including an OS GIKEN ! Lol
I know someone needs a silky o2 sim vs paying $100+ for it new.
And um, yeah, S/C stuff, etc...
Added 2 Volk Racing center caps, BC Racing coilover damper extenders and likely more to follow
Old 08-25-14, 10:35 PM
dannyboy26
dannyboy26's Avatar
^ Thanks! Bump there's still some good stuff left including an OS GIKEN ! Lol I know someone needs a silky o2 sim vs paying $100+ for it new. And um, yeah, S/C stuff, etc... Added 2 Volk Racing center caps, BC Racing coilover damper extenders and likely more to follow
PM sent on O2 sim
dannyboy26 is offline
Old 08-27-14, 05:48 PM
mikellucci
mikellucci's Avatar
PM's replied, thanks guys
Old 08-28-14, 09:24 AM
isfdude
isfdude's Avatar
The drive shaft, It's the same design as oem with the center support bearing and all?
isfdude is offline
Old 08-28-14, 05:43 PM
mikellucci
mikellucci's Avatar
The quality of the DS is AMAZING!! It's design overcomes all of the shortcomings of the stock shaft.
It's a 3.25 Carbon fiber shaft using a 108mm CV that eliminates the front and rear guibos. The shaft and its custom wound fiber is designed for 1000Hp and a critical speed of over 220MPH. The back has a Solid 1350 joint (same size as a Top HP Drag car) and comes with all hardware. Its torsional properties are what will make it so good... This and the fact that the Guibos and soft hanger are no longer there to make the drivetrain feel soft or soggy, it will have a more athletic feel as well as all the benefits one should expect from such design.
To have the unit on hand and look it over I am beyond impressed! And that's coming from a repeat customer that used one of their DS on a high HP swapped is300.
This one is
Old 08-28-14, 07:23 PM
vpcutes
vpcutes's Avatar
How much for the tail light shipped to CA 95136
vpcutes is offline
Old 08-28-14, 07:40 PM
Evil Teo
Evil Teo's Avatar
cabin air filter? I just need the brackets
Evil Teo is offline
Old 08-30-14, 12:49 AM
LexusGuyyy
LexusGuyyy's Avatar
oh my god SC mounts! I want so bad
LexusGuyyy is offline
Quick Reply: OH ISF & ISx50 - part out - OS GIKEN, interior, suspension, S/C, BBK, lots!!
