LA FS: Nearly Complete DIY rear mount turbo kit w/ MAPECU3/Win7tablet and IS350 Partout
Old 08-14-13, 09:27 PM
06isDriver
06isDriver's Avatar
Default FS: Nearly Complete DIY rear mount turbo kit w/ MAPECU3/Win7tablet and IS350 Partout
******* UPDATE ON PRICES!!!!!*******
My loss is your gain! I dont have any use for any of these parts anymore because I've moved on to the Mercedes CLS55 AMG and simply cant use any of this.
$300 - Precision T3/T4 6031e turbo - never personally used it but no shaft play
$50 - Turbosmart synapse BOV
$50 - Tial Sport 44mm Wastegate with 14 psi spring
$125 - stainless steel 2.5" midpipe for ISX50 RWD
*****MAPECU3 PACKAGE***** - $650 shipped
1 -MAPECU3 without the harnesses. You can purchase new ones from MAPECU. You'll need a vacuum hose as well. Unfortunately, I couldnt even open the hood to attempt a harness rescue. I just grabbed what I could. With the MAPECU3 piggyback, you'll be able to fine tune your AFR and timing for gaining that extra 20whp NA or to control your boosted setup for safety or to push the limits. To run it in open and closed loop modes (boosted setup) you'll need an additional AFR calibrator module from MAPECU as well, although it isnt expensive.
1 - Dual Core Windows7 Tablet with MapCAL3.x preloaded.
1 - Tablet car mount.
Pics
[URL=http://s1031.photobucket.com/user/ksberthelot/media/20130814_190505_zps458cdc98.jpg.html][/URL
I've also got some other parts laying around like:
Black trunk carpet floor mat - $40
stock intake w filter - $30
oem rear sway - $20
rear slotted/dimpled rotors - $75
2 bottles Toyota brake fluid free with rotors
all prices + shipping and 3% paypal fees. Hit me up with offers, you might be surpised.
Lets get this stuff gone!!!
Thanks for looking.
06isDriver is offline
Old 08-14-13, 10:54 PM
yammy
yammy's Avatar
I'm interested in rear sway bar!
yammy is offline
Old 08-14-13, 11:04 PM
Windaica
Windaica's Avatar
Im interested in the wheel spacers!
Windaica is offline
Old 08-15-13, 05:42 AM
06isDriver
06isDriver's Avatar
all pms replied.
I just thought about talking with the local shop who installed my mapecu to see if he wont let me make copies of his binder full of notes regarding the install on the IS. I'll let you guys know.
Old 08-17-13, 05:15 AM
06isDriver
06isDriver's Avatar
Start of vacation bump! If you would like to buy separate parts and pieces just shoot me a pm or respond in the thread.
F-sport rear sway is SOLD!
Old 08-17-13, 08:40 AM
wh1te0nr1c
wh1te0nr1c's Avatar
if the spacers are still up for grabs hit me up bud. ill come pick them up
wh1te0nr1c is offline
Old 08-17-13, 08:43 AM
wh1te0nr1c
wh1te0nr1c's Avatar
as for the rear mount turbo.....very tempting.....
Old 08-22-13, 08:18 AM
06isDriver
06isDriver's Avatar
mostly everything is still for sale except for the fsport rear sway bar.
I will part out now. The interest isnt there for the whole shabang.
New Prices:
$700 - MAPECU3 with WIndows7 touchscreen tablet preloaded with the latest version of MAPCAL and stand
$300 - Precision T3/T4 6031e turbo - condition unknown but no shaft play
$75 - Turbosmart synapse BOV
$75 - Tial Sport 44mm Wastegate with 14 psi spring
$150 - stainless steel 2.5" midpipe
all other stock parts I listed in original post still for sale.
wh1te0nr1c, the spacers are yours, just come pick them up next week. FRee for you!
Old 08-22-13, 06:20 PM
blackgpgt
blackgpgt's Avatar
Any chance that midpipe is for an awd?
blackgpgt is offline
Old 08-23-13, 09:00 AM
06isDriver
06isDriver's Avatar
nah, its for the rwd
Old 08-23-13, 10:44 AM
wh1te0nr1c
wh1te0nr1c's Avatar
New Prices:
werrrdddd get me that cellular! ill be passing through br on my way to hot import nights next friday.
Old 08-26-13, 07:49 AM
06isDriver
06isDriver's Avatar
bump! Updated prices and availability in original post.
I need this stuff gone so I can start modding my new car!!!
Old 08-26-13, 12:04 PM
heyarms
heyarms's Avatar
How difficult is it to do the tuning? Does it take a lot of knowledge to do, is it "dummy proofed", or should my shop mess with it? I've never dabbled with any tuning personally, so i would be at the hands of google if doing it myself. lol
Also, ball park price on harness from Mapecu? I see about $2-300 on their page (well the page they recommend buying from) for other Lexus models, but IS250/350 not listed, so curious if its upcharged for being "custom".
heyarms is offline
Old 08-26-13, 12:50 PM
06isDriver
06isDriver's Avatar
The inital installation and tuning should probably be done by your trusted tuning shop. MAPECU is a pleasure to work with and will go above and beyond to help you install it correctly. Once it is installed, a dyno tune is highly recommened. It is NOT dummy proof and you'll have to operate it and make changes to your fuel trims with a bit of reason and temper. For instance, my stock ecu was keeping the AFR at about 11.2 near readline and pulling timing before each shift. After discussing what I wanted with my shop, we decided on a targeted AFR of 12.0-12.3 near redline and adding 4 degrees of timing back in. This setup was considered pretty safe and netted me about 20whp on my NA setup.
if you go here:
http://www.mapecu.co.nz/online-shop/
you'll see the prices listed for the MAPECU3 harnesses.
You'll need these parts in order to have a fully working mapecu:
Product Qty Price
MAP-ECU3-VAC 1 $10.00
MAP-ECU3-18-1M * 1 $40.00
MAP-ECU3-16-1M * 1 $35.00
MAP-ECU3-IAT * 1 $35.00
MAP-ECU3-IAT-2M* 1 $15.00
5 items Subtotal: $135.00
For those running superchargers, you may need these two additional modules depending on your goals:
MAP-ECU3-AFR 1 $119.00
MAP-ECU3-REL 1 $75.00
Considering the mapecu sells new for $695, I have discounted it accordingly AND you're getting a Windows7 dual core tablet to run the whole thing practically for free.
Old 08-26-13, 03:38 PM
skottydznt
skottydznt's Avatar
so essentially, I can purchase the tune and run it on my N/A is 350 2006 with only the addition of 135$ plus your mapecu and a shops set up time and get about 20 hp to my car?
skottydznt is offline
Quick Reply: LA FS: Nearly Complete DIY rear mount turbo kit w/ MAPECU3/Win7tablet and IS350 Partout
