CA FS: V-LEDS LED DRL Kit w/Parking Lights
I'm selling V-LEDS' recently released LED DRL kit, which comes with matching LED parking lights. Both the DRLs and parking lights are 6000K in color (white with a hint of blue). This latest design from V-LEDS (released last month) requires no messy wiring harness, but instead uses two plug and play modules to ensure the LEDs receive a constant voltage to prevent flickering. The kit practically brand new, I only tested it for ~2 hours. $50 firm.
From V-LEDS' website:
V-LEDS 6K 9005 HIGH POWER LED DRL + PARKING LIGHT KIT 06-UP LEXUS IS250 IS350 SC430
Includes 2 DRL Modules, 2 High Power 6W 9005 LED bulbs and 2 High Power 194 bulbs with Optical Lens for 06-Up Lexus DRL System. Simply connect plug n play DRL Module to vehicle harness, then install 9005 LED bulbs. Replace parking light with Perfect Match High Power bulb. Module fits inside headlight cover, no need to drill holes. Easy plug n play installation.
Wow, I have a lot of PM's to clear out re: this thread. Sorry guys, but the LED DRL + parking light kit was sold to a Bay Area local (who contacted my first anyway) a few hours ago.
We installed the kit together and it works really well. Again, there is no need for a relay to the battery, and you can even tuck the module and connectors all behind the moisture shield. So no drilling, no wires exposes AT ALL, and no flickering.
For those interested, you can buy the kit WITH parking lights here for ~$70 shipped: http://www.v-leds.com/Vehicle-Specif...-p9371399.html
Without parking lights for ~$60 shipped: http://www.v-leds.com/Vehicle-Specif...-p9371398.html
^ The main advantage with the new design is the cleaner install that requires no drilling or relays and is 100% plug and play. Visually, the older style is a little brighter and fills out the housing more completely. The new design is also bright, but has 3 distinct beams that come out from the center of the housing since the design uses 4 giant LEDs (3 firing radially to cause that beam effect, one straight forward) instead of several tiny ones in the old design. It's just a different look.
Got it, will keep mine, thx
