Main fuse block
Old 01-06-08, 08:59 PM
grego2
grego2's Avatar
Default Main fuse block
I have a main fuse block which is the one that is next to the battery under the hood. The part number on it is 82620-30170. It is brand new and was taken off of a wiring harness when a rodent chewed through my wiring harness.
$50.00 shipped anywhere in the lower 48 states.
Paypal is good as is cash if you want to pick it up if local. I am in Sacramento CA.
Thanks
grego2 is offline
Old 01-06-08, 09:01 PM
grego2
grego2's Avatar
here is another picture of the part number.
grego2 is offline
Old 01-07-08, 09:10 PM
grego2
grego2's Avatar
no longer for sale here
grego2 is offline
Old 04-25-14, 10:31 PM
DUMI
DUMI's Avatar
I blow out my fuse block on my 07 is250, the part number on it is 82620-30170 I really need help and replacing it. asap, pictures would help a lot. staying all night trying to figure this out. I alreay bought a new one.
DUMI is offline
Old 04-26-14, 05:04 AM
mikellucci
mikellucci's Avatar
^You need to remove the black panel covering surrounding the relay assembly. It's held on by a bolt or two and several pry tabs. The fuses in the corner are a clip on piece that remove as well. It's tricky but look closely at it and you'll see all the tabs.
Once removed all the wires are bolted on with 10mm and 8mm bolts. Just undo one at a time or number everything in order.
Sorry, I only have a few rough pics when I had mine apart. You can see all the wires loose not connected.
mikellucci is offline
dn1ce64
08-24-17 05:50 PM
TheDeep
08-26-16 07:25 PM
KMB57
06-16-13 05:40 PM
pconfar
10-03-12 07:50 AM
quincy50
RX - 1st Gen (1999-2003)
12-10-10 05:00 PM
Quick Reply: Main fuse block
