NY 98 GS300 w/ CD009 six speed manual
Old 11-02-15, 09:37 AM
maxEX84
maxEX84's Avatar
Default 98 GS300 w/ CD009 six speed manual
have a 98 Lexus GS300 with a Nissan 6 speed transmission swapped in from a 2007 Infiniti G35. I'm military and about to move in the next month and it would be too difficult for me to bring this with me across the country. I put a lot of work into this car after owning it the last 2 years. So here's a little run down on what I've put into it:
-Nissan CD009 6 speed transmission
-custom shifter modification
-modified driveshaft
-modified 350Z clutch pedal assembly with master cylinder
-custom wiring done to have manual transmission work with automatic transmission ECU( No CEL codes for the transmission)
-several lights on car changed to LED(fogs, hi-beams, parking lights, interiors lights...)
-HID headlights
-rebuilt front brake calipers
-replaced all O2 sensors
-replaced valve cover gaskets
-replaced head unit with Nexus 7(2013) tablet
-replaced all speakers except sub with Kicker speakers with all new wiring to 2400 watt 5 channel amp.
-Swapped factory brake booster/abs unit with Toyota Avalon brake booster and master cylinder
-deleted foot pedal cable parking brake assembly
-installed hydraulic handbrake
There may be a couple things I'm forgetting right now but that's what I have. I'll be cleaning the car up more as the days go by.
Looking to get at least $5500 but I'll entertain offers.
Sorry... NO TRADES. I'm moving across the country and can't bring the car with me. My loss is your gain will also throw in a stock driver seat from a 2014 mustang gt since the stock seat is a little worn out.
*As of right now, my original shifter idea will not work out and I can go ahead and put together a shifter bracket that will work, the Nissan trans is a bit long for this car and without a speed sensor on the trans a code pops up for the vehicle speed sensor which shouldn't be a problem if you were to get a speed sensor converter. If you have any questions just send me a message
maxEX84 is offline
Old 11-02-15, 09:39 AM
Chops@MVP
Chops@MVP's Avatar
Can you post up some pics please.
Regards,
Robert
Chops@MVP is offline
Old 11-02-15, 09:56 AM
maxEX84
maxEX84's Avatar
I will when I get home later, I'm at work right now.
maxEX84 is offline
Old 11-09-15, 04:40 AM
maxEX84
maxEX84's Avatar
maxEX84 is offline
Old 11-09-15, 03:07 PM
SoCal Cyco
SoCal Cyco's Avatar
wrong section, this needs to go in the car classifieds.
SoCal Cyco is offline
sanjaygb
04-26-21 04:05 PM
PeteGS300
02-06-16 12:30 AM
SC400MAN
10-10-06 12:41 PM
Quick Reply: NY 98 GS300 w/ CD009 six speed manual
