CT FS: 2000 Brake Master Cylinder
SOLD! FS: 2000 Brake Master Cylinder
SOLD!
Approximately 90k miles on the brake master cylinder, also called the hydraulic brake booster module. Comes complete. Everything works as it should (ABS, traction control, emergency brake assist, regular braking) and there are no check engine lights or codes.
It was replaced because the pedal feel became less stiff than usual after changing calipers, pads, and rotors. The replacement unit had an identical pedal feel and I was never able to find a reason for the change in pedal feel, but I strongly suspect it simply needed to be bench bled, which I never did. Again, I used this master cylinder for about 15k miles in this condition and it works fine. There is no difference in performance other than pedal feel.
$250 plus shipping.
$250 plus shipping.
Brabusx2
03-05-18 03:25 PM
