OR JDM Aristo Front Sway Bar Upgrade 28.6mm
I am selling an original Aristo front sway bar from Japan. This larger diameter sway bar fits all GS300/400/430 models; 98-05.
This is a factory upgrade that bolts right in, just a larger 28.6mm diameter. Comes with brand new performance bushings for increased handling.
Includes the original end links, bar, and bushings. You can reuse your oem bushing brackets and endlinks as well.
$200 shipped for everything.
Email me at M.Nelson.OR@gmail.com
Thanks!
Thanks!
I believe the part number in question is 48811-30560; which I think is the same between Japan and the US. Would you please share more about this 'factory upgrade' (or origin of this part you are selling) as we are having a hard time finding more information?
Thanks!
5% Club. Killing it!!!
Hi, I'm getting a few comments from other members and wanted to verify this comment.
Thanks!
Thanks!
http://www.cusco.co.jp/cusco_catalog/#128
On the other hand, from Energy Suspension's website, it says stock is 28.5mm.
http://www.energysuspensionparts.com...sp?prod=181123
I understand we're splitting hair here of a difference of 0.1mm, but just wanted to confirm the claim that it is a 'factory upgrade'...
I'm also just genuinely curious because car manufacturers do make ever so slight changes to adapt to different countries. For example, our A650 transmission has 2 or 3 different settings where you can adjust how strong the gears shift... if I recall correctly, the European market GS was set at the hardest setting and the North American market GS was set at a milder setting.
