NY WTB Front RCA
Old 07-08-14, 10:58 PM
KingNasGS4
KingNasGS4's Avatar
Default WTB Front RCA
Like the Title says, Just trying to get an additional drop and get some LS400 Calipers
No camber wanted.
Let me know what you have.
Thanks
KingNasGS4 is offline
Old 07-09-14, 05:16 AM
baddis es
baddis es's Avatar
PM'd........
baddis es is offline
Old 07-09-14, 01:41 PM
KingNasGS4
KingNasGS4's Avatar
Forgot to mention that the maximum I'm looking for is ~ 25mm
Old 07-09-14, 05:09 PM
LudeNsoL
LudeNsoL's Avatar
Call me I got a pair (917) 328-0346
LudeNsoL is offline
Old 07-10-14, 10:57 PM
GSGenesis
GSGenesis's Avatar
Like I suggested to the other guy looking for a set, since my goal here is to look out for the OP, just call Mike over at FIGS. Ls400 brake install? Just get the bare minimum 17mm which he sells strictly or was made around, the fitment of the BigBrake kits. which he sells for cheaper than most people want for there used sets... He's a good guy too. Cheers. I just got a set of the dowel ones for BigBrake kit install. There perfect.. I'll post a pic
GSGenesis is offline
Old 07-13-14, 12:56 PM
KingNasGS4
KingNasGS4's Avatar
Thanks. Id like to see a pic. Before and after
Old 07-13-14, 03:56 PM
sam430
sam430's Avatar
The dowel can be bought with more than one size. You can couple it and get a longer bolt from figs. Remember to tighten it properly.
sam430 is offline
Old 07-15-14, 09:47 PM
GSGenesis
GSGenesis's Avatar
Sure, but your like to see a pic of before and after what? Ride height? Or brakes installed as well? Or a close up of the RCA's installed? Like he said ^ you can buy his dowel's at 17mm, which would just be one, 17mm spacer that's designed to make it so the castle but and what not clears, or, if you'd like even more if a drop, you can get additional ones that are designed to stack and interlock kind of into one another. My car is goin to look the same because in going to raise my coils up 17mm of ride height so it is at the exact height I've dropped it to right now... If I just wanted to lower the car, I've got tons left to lower via coil overs man... If that's what you meant..
redmanV8
SC400 / 300 Classifieds
05-29-15 10:11 AM
Yohan84
05-10-15 09:43 AM
maxx430
07-10-14 10:54 PM
94_soarer
03-02-09 04:38 PM
dwebb99
11-08-08 03:14 PM
Quick Reply: NY WTB Front RCA
