GA Brembo GT 14" Big Brake Kit
Old 11-18-13, 05:41 PM
CHINCHIN
CHINCHIN's Avatar
Default Brembo GT 14" Big Brake Kit
1250.00 plus shipping. Kit will need some work. I purchased the kit off of a member here a while back. I think he was out of Cali. I never got the chance to install the kit on my car. Please keep that in mind. Rotors and pads appear to be fairly new. Most of the scratches on the rotors and calipers are from the seller I purchased the kit from doing a poor job packaging/shipping the kit. We worked out a reduced price so all was forgiven. There are 1 or 2 holes on the mounting brackets that will need to be cleaned out due to the threads being damaged. Worse case scenario, you will need to put in a helicoil or timecert. Google if you dont know what that is. It happens to all Brembo's even the OEM Brembos on Subaru's, Mercedes, etc. The different metals fuse together and damage the threads on the brackets... you MUST use anti seize compound when mounting the calipers... Calipers were originally black, previous owner only painted the visible outside half of each caliper pearl white What you see is what you get.
CHINCHIN is offline
cssnms
GX - 1st Gen (2004-2009)
23
10-08-18 06:41 AM
Venturi
RC F (2015-present)
06-24-15 05:29 PM
ASPLS430
07-03-06 07:11 PM
ILOVEGIRLS
Suspension and Brakes
15
01-28-05 01:31 AM
GS400kid
07-31-04 09:45 AM
Quick Reply: GA Brembo GT 14" Big Brake Kit
