1" Front RCA blocks, 6061 aluminum and include bolts, washers and bushings. These are used but not a wear item so no different (outside of a little dirt) then you would get with brand new, bolt on and go.
I'll grab some pics this evening, they are custom made and look similar to the sage RCA's but they are a true 1" and not purple. These RCA's are 1" which is 25.4mm (for reference 30mm is 1.18"). First with cash/Paypal takes them.
RCA's will help your camber but I can't give you an exact amount. By nature they will keep your control arms in better alignment as well as allow you to run the same drop (but have an inch more suspension travel) so the car will look the same but ride much better and also have better camber. RCA's don't have a set number they will provide as it will be different on each setup, however it will be a step in the right direction and not worse camber.
No pics of it installed handy, it will give you a 1" drop over your current drop or you can have the same ride height with an inch more suspension travel. I'm located in North Seattle if you want to pick up
