CA Zeal Function Zi Coilovers
Old 09-09-12, 02:54 PM
milky
milky's Avatar
Default Zeal Function Zi Coilovers
As the title says, my zeal coilovers are for sale. Used approx. 25k miles.. They perform great, slams the car, ride nicely. Nothing wrong with them, just going back to stock. These are quality coilovers
Asking $850 OBO, Located in Socal los angeles, San gabriel valley area. Locals have priority, but also willing to ship at buyer's expense. Thanks for looking!
milky is offline
Old 09-09-12, 06:09 PM
LuxuryGS3
LuxuryGS3's Avatar
Whoa... What's the spring rates? I see swift springs so I assume they're not soft..
LuxuryGS3 is offline
Old 09-09-12, 10:38 PM
milky
milky's Avatar
The Function-Zi was produced with comfort in mind. Within the Function Series, our systems are produced mainly through circuit feedback, but the Zi was produced with the focus of fun, smooth, enjoyable driving in mind. This is the ""feel good"" system developed for the ultimate street user. A coilover system that is produced with the same quality as our more racier systems, but meant for the older, more mature adult driver that keeps comfort as his/her priority while enjoying the drive. Our easy-to-read and use, 6-Way Piston Valve Shock (PVS) Dial mechanism adjusts the rebound/compression force. Dial can be turned either direction infinitely. Our lightweight, Aluminum Rigid upper mount with rubber bushing decreases noise level and eliminates vibration through absorption. (Strut-type uses Pillow Ball camber adjustable upper mounts for direct feel of suspension motion while helping to decrease piston rod tension). Rubber dust boots protect piston shaft against debris and other forms of damage to help increase life. ID60 SWIFT Spring (Street or Hard rates) maintains stroke and ensures a ""seated"" fit with upper and lower portions processed to a flat cut. Includes a single, monotube-type, chromoly-coated, steel-type shell casing Shock Absorber. The Adjustable Shock-Stroke System is a separate, adjustable lower cup/bracket used for height adjustability which eliminates problem of sacrificing stroke and altering spring tension. Spin the mechanism over the threaded shock casing up to lower (and down to raise) vehicle height. All Zeal Function Series systems include this height-adjustable system.
Street Spring Rates: FT: 18kg/mm RR: 12kg/mm
milky is offline
Old 09-10-12, 12:16 PM
chrispy
chrispy's Avatar
Zeal is the good stuff. Good luck Mike!
chrispy is offline
Old 09-11-12, 10:49 PM
milky
milky's Avatar
Thanks Chris! willing to entertain offers, pm me
milky is offline
Old 09-11-12, 11:09 PM
LuxuryGS3
LuxuryGS3's Avatar
Ah, a little softer than what i'm aiming for.
GLWS though man. These are some quality coils right here.
Old 09-14-12, 12:41 PM
gsjason300
gsjason300's Avatar
We made a deal a year ago! Lmao dont know what hap but text me milky im the one that bought those fogs off u long time ago 6262212013
gsjason300 is offline
Old 09-16-12, 10:42 AM
milky
milky's Avatar
haha I haven't been on the forums for a while, i'll send you a text jason
milky is offline
Old 12-05-12, 11:48 AM
milky
milky's Avatar
still available.. msg me!
milky is offline
Old 12-10-12, 08:22 PM
TNH
TNH's Avatar
Can you go really low with these? Any pics of them on your car so I can get an idea of the stance you can achieve with them?
TNH is offline
Old 12-11-12, 12:36 AM
milky
milky's Avatar
it'll be around this height, rears are fully lowered, the fronts can go a tad lower if you have the proper clearance.
milky is offline
Old 12-14-12, 02:59 PM
milky
milky's Avatar
bump any takers? i'm open to offers, i'll even throw in a JP flag for the buyer!
milky is offline
Old 12-25-12, 10:13 PM
Hameed
EV ftw!!!
Hameed's Avatar
How do these coilovers compare with
1. Tein Flex coilovers - in terms of comfort and noise levels?
2. OEM setup - in terms of comfort and noise levels?
Where are these made? Japan?
Hameed is offline
Old 12-30-12, 10:25 PM
milky
milky's Avatar
Hi Hameed,
1. I'm not sure how they compare with the flex as i've never had those coilovers installed, sorry. I can compare them to tein HA, and stance GR+.. Of these, i can say that these zeal coilovers are definitely the best in terms of ride quality, noise levels, and overall performance.
2. Definitely noisier than oem set up, but i'm sure all coilovers are. If OEM comfort is 10, i would say the zeals would be around a 7 or so. I'm not sure how else to rate comfort, lol sorry.
And I'm not exactly sure where these are made, again sorry. If i would have to guess, I would say non USA, but again not sure.
Hope this helps!
milky is offline
Old 12-30-12, 11:03 PM
sakataj
sakataj's Avatar
Zeal is made in Japan Mike, Endless (the brake company sells them) so if you ever need them rebuilt EndlessUSA can rebuild them in house
here is a old review against the Tein Flex's Hameed
https://www.clublexus.com/forums/sus...coilovers.html
Tein IMHO have always been junk and i hate them......
sakataj is offline
Quick Reply: CA Zeal Function Zi Coilovers
