CA FS Complete Air ride System Easy Street, Accuair, and UAS
MODS would you please allow me to post this in the GS and SC classifieds as it is a high dollar item and fits both platforms. Thanks. OK I have $3200 into this kit. It's not perfect but all is in good shape & comes with 2 new extra bags(Not Pictured), extra new air filters, and an extra new pump relay. There are some scratches on the blues, some rust in the air tank from moisture. If I were to re-install this in my SC again I would get 2 new press fittings for the dryer, all new air line and an aluminum tank. This is everything I had on my car and was my daily driver for years with this setup. The pumps and relays are already wired mounted on plywood and cut to drop right into the CD changer location on an SC. Major time saver. The air manifold is compact runs right to the pressure sensors that tells the controller exact pressure each corner so you can get an accurate ride height with out all the guess work. It looks like a lot of wiring but its literally a power and ground to the relays and to the controllers computer, run the air lines and your mostly done.
Duonghtx
14
08-13-12 04:55 PM
