CA FS Universal Brembo Brake Covers
ASKING $20
Local Pick Only At This Time
Brand New
Material: ABS Plastic With High Quality Coating, Nut & Bolt
Color: Red
Quantity: 2 pair(front+rear)
Front: Length = 24cm(9.50 inch) Height = 7.5cm(2.95 inch) Deep = 4.1cm(1.60 inch)
Rear: Length = 18.5cm(7.30 inch) Height = 5.5cm(2.18 inch) Deep = 5.5cm(2.18 inch)
Requirement :
Rim wheel must be 16 inches or bigger
2 cm or more clearance gap between caliper housing and your rim wheel
Installation Guide :
Remove the wheels and clear the stock caliper housing
Apply some silicone glue between caliper cover kit and caliper housing (Use the high Quality Silicone Glue (be durable with high temp)
Attach the caliper cover kit to the caliper housing
Move the caliper cover kit to the suitable position and fix it with temporary paper tape
Allow the silicone glue to dry
Reattach the wheel and spin the wheel to check the clearance
You're Finished!
Not looking to ship at this time. Message me for details
Brand New
Color: Red
Requirement :
You're Finished!
