CA Fs: Ls400 bbk
Old 09-23-10, 05:43 PM
lowkeySC
lowkeySC's Avatar
Originally Posted by TLcoats
If only the color wasnt red... Guess i could just get them repainted. So let me get this straight, I have oem 17's so i would need at 15mm spacer in the front and then i could shave down the tie rod bolt? OR do i HAVE to buy an RCA?
you can just shave off. RCA is just the other option.
GLWS man. i would have bought these if i had the money.
lowkeySC is offline
Old 09-24-10, 12:12 AM
Wesssup
Wesssup's Avatar
Originally Posted by nathan1352
So as I understand it, these bolt directly to an sc300 with no modifications except I'll have to buy the ls400 rotors and pads?
I believe you have to cut or bend your dust shield, which shouldn't be a problem.. Other than that, it should bolt right on. Here's some info on whether or not to get new bolts. Some people recommend it, others don't, it's your pick.
https://www.clublexus.com/forums/sus...-calipers.html
Originally Posted by Gennady7
I will take them if they fit.
I have the 3gs 18" 5 Spoke rims. Will these bad boys fit my setup? I really like these brakes.
https://www.clublexus.com/forums/sc-...clear-bbk.html
eliteskills posted the wheels that would clear this setup and the 18" 5 spoke seems to be on the list!
Thanks!
Wesssup is offline
Old 09-24-10, 02:23 AM
VNN326
VNN326's Avatar
my offer still stands!
VNN326 is offline
Old 10-14-10, 10:26 AM
96gti2.0t
96gti2.0t's Avatar
are these brakes still available? email me at davidongiri@gmail.com if they are
96gti2.0t is offline
Old 10-14-10, 12:54 PM
PHML
Master Thread Closer!!
PHML's Avatar
OP....you should clarify if all the parts are there...I dont see the spring plate to keep the pads in place.
PHML is offline
Old 10-14-10, 12:59 PM
mamono
mamono's Avatar
I have the early 3gen 5 spoke GS rims and Supra TT brakes, they do not clear, I need a 10mm spacer to clear. LS400 brakes are supposed to be similar size, but a little smaller than Supra TT brakes. You might get away with a 5mm spacer, but you're going to need a spacer nonetheless.
mamono is offline
Old 10-15-10, 08:52 AM
vwynn
vwynn's Avatar
ull need RCA's or shave down the bolt on a 2gs
vwynn is offline
Old 11-12-10, 11:58 AM
PHML
PHML's Avatar
Shaving bolts =
PHML is offline
goodyonsen
Suspension and Brakes
01-15-16 03:26 PM
dwebb99
SC400 / 300 Classifieds
01-14-15 05:45 PM
dwebb99
02-20-12 06:18 PM
GSteg
30
06-20-09 05:52 PM
Quick Reply: CA Fs: Ls400 bbk
