WTB Steering/Ignition Sub Assembly
Looking for the steering sub-assembly which mounts onto the steering column and also provides the mount for the ignition lock and barrel. Please note, I just need the sub-assembly as I do have the ignition lock and barrel. Mine appears to have been hacked and the contact point for the steering tilt has broken which means the steering wheel doesn't tilt up when the key is removed and return when the key is inserted.
Ideally, I would like to get the connecting wire from the sub-*** embly to the tilt ECU as well since the connector on my wire is damaged.
Refer part numbers 45280A and 84052 of the attached.
Thanks,
Nik.
Thanks,
Nik.
