1st Gen GS3 black shifter surround & ash tray
I need just the center black shifter surround that indicates PRND2L, not entire shifter panel and ash tray surround, not the entire ashtray. One needle for tach or speedo for cluster, working or not..
I have for sale all for 1st gen GS3, an astray minus the surround. A 180 amp alternator, can be set up in a few different configurations, such as internal/external regulator.
Originally Posted by jaymil31
hey
What do you want for the alternator????? Let me know soon
The alternator is $250 + shipping with an internal regulator and all new heavy duty internal parts. If you'd like to be able to set the voltage to higher than 14.4 volts then you can add an external regulator. If you'd like an external regulator it will be $320+ shipping. With an external regulator it will not be plug and play. You will have to splice 2 wires to the wires in your alternator harness. I will tell you exactly which ones.
Do you have more that one of these alternator avalible? And other than the external voltage regulator are there any mods you have to do to mount the alternator?
I think i have the shift display your looking for i will check!
