Need help to change fog light....... Plz *^^*
Old 09-27-07, 03:45 PM
DivX007
DivX007's Avatar
Question Need help to change fog light....... Plz *^^*
Hello,eveyone!!!!!!!!!!!!!!!!!!
I join this forum not too long ago.
About 1 week ago, I bought 02 Lexus SC430. and I ordered whiter fog light bulb from ebay. I got them but I do not know how to change them.
I need help to replace ugly yellowish bulb with new bulbs.
could anyone give me the instruction with picture or photo on them?
or at least where to find how to change fog light bulbs for Lexus sc430?
Thanks
Old 09-27-07, 03:51 PM
rominl
exclusive matchup
rominl's Avatar
go from the front wheel wells, that's your best bet. turn the wheel all the way and gain space
Old 09-27-07, 04:29 PM
1NEAT_SC
1NEAT_SC's Avatar
Nice looking SC DIVX007. Sharpe looking wheels too. I've never changed mine so I'll be monitoring suggestions. rominl knows a bunch so that may be the way to go.
Congrats on your purchase.
lar
Old 09-27-07, 05:40 PM
DivX007
DivX007's Avatar
how to open this wheel whells??? plzzzz......
explain in detail for me ..... THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 09-27-07, 10:26 PM
donaldp
donaldp's Avatar
You are in for a challenge.
I just replaced mine on my '07.
Raise one front corner, remove all bolts under the car that attach the corner under car shroud. Pull it back into the wheel well. Once you finally get to the housing itself, you must disconnect the plug, then you have to unclip the bulb which is snapped in then remove the bulb, reverse and you're done.
It is helpful to have a small mirror to assist you in seeing the clip that holds the light in the socket. Each side took me almost two hours. You'd think the second side would be easier but I had a much harder time with the clip holding the bulb in.
Old 09-27-07, 10:39 PM
rominl
exclusive matchup
rominl's Avatar
yes just pry over the plastic flap and i believe take out 1 or 2 clips and you should be able to pull the flap backward. i don't haev the car anymore so i am playing from memory
Old 09-28-07, 02:10 AM
cluguy
cluguy's Avatar
wheel well ftw -- rominl is right.
Old 09-28-07, 08:23 AM
DivX007
DivX007's Avatar
sounds very hard job to do 4hours!!!!!!!!!
Old 09-28-07, 09:01 AM
sexylexysc430
sexylexysc430's Avatar
Yes...Lexus did NOT make it easy to change any kind of bulb in the front of the car. Some of the small bulbs in the headlamps and bumper require the bumper to be removed in order to replace the bulb!
Old 09-28-07, 09:05 AM
rominl
exclusive matchup
rominl's Avatar
it shouldn't be so hard to take 4 hrs to change, maybe 30 mins?
btw, welcome again div check your pm
Old 09-28-07, 11:35 PM
Pearlpower
Pearlpower's Avatar
it is also very easy to install the bulb incorrectly and yet still hear the clip click into place. Install quality bulbs so you don't have to do it again. Use a mirror to ensure things go together correctly.
Best of luck, I would rather R&R the rear end on this car than change the fog bulbs. Thanks Lexus.
Old 09-29-07, 12:11 AM
rominl
exclusive matchup
rominl's Avatar
lol lee, you should have hired someone with small hands you know
Old 10-15-07, 05:27 PM
whokiid
whokiid's Avatar
holy crap replacing the fog bulbs is god damned near impossible
Old 10-16-07, 12:28 AM
DivX007
DivX007's Avatar
I did not try yet. I do not have the jack to lift the car up and try.
I should do them soon I guess *^^*
Old 10-16-07, 11:18 PM
whokiid
whokiid's Avatar
i gave up and just took it to my guy in cypress. had em both replaced with new PIAA 2500k yellows. so glad i paid someone to do it.
Quick Reply: Need help to change fog light....... Plz *^^*
