How To Change Headlight bulb
Old Sep 1, 2007 | 08:41 PM
TORTOISE's Avatar
TORTOISE
Default How To Change Headlight bulb
I tried to change the bulb today and i pulled on the rubber tube that looked to be leadin to the headlight and it just popped off whats the deal? Also i bought H7 bulbs are these right for low beams?
Old Sep 1, 2007 | 08:59 PM
LXMN's Avatar
LXMN
H7 is the correct bulb for the low beams.
If you have already popped off the rubber gasket, the bulb is held in with a metal clip. You will need to loosen this clip in order to release the bulb from the headlight.
Old Sep 1, 2007 | 09:02 PM
TORTOISE's Avatar
TORTOISE
yeah thats what i thought but i didnt want to break anything...thanks a lot!
Old Sep 1, 2007 | 10:41 PM
Xterminate's Avatar
Xterminate
hes right about h7 but somehow mine wont fit with the rubber gasket...... it seems too big for the h7 socket to reach the plug so iunno what happen there........ also the bulb i pulled out was a h4 bulb?!?!?!?!?
but h4 are only for motorcycles only
Old Oct 13, 2008 | 08:54 AM
JennGirl's Avatar
JennGirl
Hey guys,
So....I'm going through a divorce and don't have the soon to be ex to change my headlight bulb and the auto store won't help.
I've changed many on my Volvo and Saturn, but haven't attempted with the Lexus.
I know this is silly, but can someone give me "dummy" instructions so I don't break anything? I'm changing both low beams.
I'm sorry. Really appreciate anyone replying.
Old Oct 14, 2008 | 10:36 AM
Lexucan's Avatar
Lexucan
Lexucanafer
Originally Posted by JennGirl
Hey guys,
If you've done this on other vehicles, then it shouldn't be too much different on our ES. And being a female, it might even be easier for you than it would for your ex, since your hands are probably smaller than his. Smaller hands are an advantage since there isn't a whole lot of room behind the headlight housings, but if I can do it (and I have pretty big hands) then you should be ok. Just lift the hood on your car and reach in behind the headlight housing and turn the plastic base of the old bulb to unlock it so you can pull it out. The lowbeam bulbs on the '93 ES300 are #9006 halogens. Just separate the old bulb from the wiring harness by depressing the locking tab on the connector ****ALWAYS PULL ON THE CONNECTOR ITSELF, NOT THE WIRES GOING INTO IT**** and then plug in the new bulb ****BE SURE TO NOT TOUCH THE GLASS PART OF THE BULB - FINGERPRINTS WILL SHORTEN ITS LIFE**** Carefully push the new bulb into the back of the housing again and turn it to lock the base into position. Do the same on the other side and you're done.
Old Jan 4, 2009 | 06:32 AM
JennGirl's Avatar
JennGirl
Lexucan,
Thanks a bunch!!! I really appreciate it...I try to avoid calling my ex for small things (we are friends....more like annoying family members, but still!)...so I very much appreciate it. I was able to do it....I just didn't know if I should be aware of anything different with Lexus bulb changing. Many thanks for this reply and the others you have replied to for me =)
Jenn
Old Jan 4, 2009 | 03:49 PM
Walnut's Avatar
Walnut
Wink
Jenn, you should divorce the Saturn too....
Old Jan 4, 2009 | 03:59 PM
Lexucan's Avatar
Lexucan
Lexucanafer
Lexucan,
Glad to be of help.
Old Jan 4, 2009 | 11:20 PM
paintrain's Avatar
paintrain
agreed^^^^^
Old Jan 5, 2009 | 11:10 PM
Lazy's Avatar
Lazy
same here.
charliedon
Mar 19, 2017 03:30 AM
jagalchi88
RX - 1st Gen (1999-2003)
Sep 19, 2011 09:17 AM
Nicelex13
May 20, 2006 04:23 PM
1BadAzzLex
Jan 16, 2003 09:11 PM
kjbro
Oct 10, 2002 05:23 PM
