I have a bad gas mileage, how about yours ??
So, today my garage hooked the diagonise computer and discovered one of the three O2 sensor has 0 Volt, which means .... dead....
So, planning to get it changed next week.
I think O2 sensor affect the gas mileage, right?
Does your car jerk at high speeds but low RPMs?
Check out these two threads:
https://www.clublexus.com/forums/sho...d.php?t=288374
https://www.clublexus.com/forums/sho...d.php?t=295986
In addition, which cat are you referring to, there should be two precats off of the manifold and 1 cat underneath the vehicle. The O2 sensor after the main cat underneath the vehicle isn't the key for the gas mileage, that would be the two A/F sensors before the precats.
One more question, does your fusebox feel hot after a 40 min ride?
Many thanks.
Normally, the fusebox is hot because the hot engine contributes to that.
With my air intake modifications, I sometimes get an exceedingly high idle (which is great when this luckily occurs at the track, such as the time I clocked my record 17.931), but otherwise a nuisance.
The one thing that comes to mind right now is that the spark plugs may have some fouling and as such the combustion doesn't have as much efficacy, thus lower gas mileage. A Check Engine Light wouldn't necessarily pop up in this case. If you were here in Mexico, I could run a gas analysis test to see your HC (hydrocarbon or unburnt fuel count) and verify this better. Has your mechanic looked at any of the plugs.
The only other source of a higher volume of air without touching off a Check Engine Light is the area around the airbox where the air filter is kept and over time it can develop warpage and near the seams there are areas where extra air can seep in. Additionally, some air can seep in through cracks on one or both exhaust manifolds just before the A/F sensors.
I would make absolutely sure that MAF sensor is clean and that it is not missing and of the two threads inside the sensor itself as I showed in the picture on the other page. A dirty sensor is just going to let air pass in and it won't be properly recorded.
