SC300 12v Fuel Mod w/ Pictures - FAQ
voltage drop over 20 feet of small gauge (whats it - 14?) wire drops voltage all the way back to the fuel pump...
i was using 10ga supply, and then the stock green wire or w/e, and the wire melted. . .
my new plan is to run the second pump only off a new wire, and tap INTO the existing wiring of the fuel pump to trigger a relay. . .
i'm not having fuel problems really, the car goes lean for about 0.5seconds when i hit the gas, then the pump gets 12v
all fuel pumps flow significantly more at higher voltage... the stock wiring has a little more than 1 volt drop at 17 amps (the max current draw of a walbro 255 pump) stock charging system should be around 14 volts at the battery, by the time it gets to the pump, you are at or below 13 volts... at 12 volts, the 255Hp flows 58 gallons per hour at 40 psi, but at 13.5 volts, it flows 68 gallons per hour...
going to a 8 gauge wire decreases voltage drop to .15 volts, so, it's worth 6-8 gallons per hour increase in pump capacity on the Walbros... seems to be worth it to me...
without the wire upgrade, you are effectively running a 220 lph pump...
The fuel mod is fine.
Just bypass the fuel controller and use the OEM wires.
This mod would slightly reduce life cycle of your fuel pump.
Not a big deal.
I agree with mitsuguy
By the way, why would you want to put walbros fuel pump in SC???
I rather install the reliable Supra TT fuel pump.
It would give you as much fuel as you need if you are not running less than 800+ HP. If you want more fuel, get another TT fuel pump and dual feed it.
You would run out of gas money before your engine runs out of fuel
By the way, it is highly recommended to get the fuel pressure gauge before doing any fuel system mod. At least, you would know what your system is putting out before blowing up your engine!
the walbro's are only going to be stressed under high load, even at 5000 rpm, if there is no load on the car, then fuel requirements are barely above idle...
also, if you look at the flow sheet I posted above, you will see that at 12 volts,
the pumps supply far less than they do at 14 volts, which is what a proper vehicles charging system should be at...
also, I haven't ever heard of a walbro pump actually dieing ever...
but yes, the Supra pump would be ideal, nothing like OE reliability, they can be pricey however
OK, here is my Dyno chart.
Boys and girls, this is what we are talking about.....
As you can see, I have problem right before, during and right after the big turbo is on! It becomes stable as soon as both turbos are fully boosting.
Actually, my engine ran lean during transition!
Scary!
The Supra TT fuel pump is capable of supporting up to 800 HP.
I am going to dual feed TT fuel pumps (like my Z32TT) when I single it.
That's all the fuel I need.
I rather bet on TT fuel pump than Walbros.
Especially, when I am boosting requiring more fuel.
I rather spend little bit more money than blowing up my engine.
I am correcting this transition problem by installing the AFC and tuning it.
-v
