What offset is recommended for 18x8 0r 18.7.5 rims on 2001 LS430?
Old 06-22-07, 11:42 AM
DanozLS430
DanozLS430's Avatar
Red face What offset is recommended for 18x8 0r 18.7.5 rims on 2001 LS430?
Looking for rims and wondering what offset should I be looking for when shopping for 18x8 or 18x7.5 rims? I was also going with 245/45/18 tires to match closer to stock diameter set up. I used this website to help. http://www.1010tires.com/TireSizeCal...mp;vehicle=yes Will a 18x8 with +38 offset work or 18x7.5 with +35mm offset? Any suggestions and does style matter also?
Old 06-22-07, 12:53 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
You need to make sure that the wheels are going to clear the brakes...
offsets of 30-40mm will work ok, brake clearance is the thing to check for first...
Old 06-22-07, 12:56 PM
bb430
bb430's Avatar
I think the offset you have would be ok. You can go back to your link and click on "tech section" then go to "wheel offset calculator" and put all your numbers in to see where the new wheels will sit. They should be just about flush with thw fenders and don't need to roll the fenders at all.
Old 06-22-07, 01:45 PM
DanozLS430
DanozLS430's Avatar
Do you know what is the stock size rim and offset for my 2001 LS430? I am on the website in the tech section and found the Wheel Offset Calculator which would let me know how it looks. I can't seem to find the offset of my stock 16" chrome rims.though.
Old 06-22-07, 08:02 PM
bb430
bb430's Avatar
I think all the LS430's wheels 16",17",18", are +45 ET(45 offset) because they are all 7.5" wide.
Old 06-23-07, 12:21 AM
DanozLS430
DanozLS430's Avatar
Thanks for the info bb430. Now I can start my rim shopping. Would a +38 be more inwards or outwards towards the fender compared to stock size, let's say in a 18x8 rim?
Old 06-23-07, 12:27 AM
Caoboy
Caoboy's Avatar
since when did the ls430 run 16? i though they were all 18's because of the brakes.
Old 06-23-07, 12:31 AM
DanozLS430
DanozLS430's Avatar
My 2001 LS430 came with stock chrome 16's or optional 17's with sports package. Later models came stock with 17's and you could upgrade to 18's if wnated.
Old 06-23-07, 06:31 AM
mitsuguy
mitsuguy's Avatar
outwards..
Old 06-23-07, 11:17 AM
DanozLS430
DanozLS430's Avatar
Originally Posted by mitsuguy
outwards..
So let say stock is 16x7.5 with 45 offset and new replacement rims are 18x8 with 39mm offset. According to the offset calculator in differences, the inner clearance remains the same (the inside of the wheel to the strut housing) and the outer position extends an extra 12mm (position of the outside edge of the wheel). 12mm converted to inches is .4724 inches. Does this mean that the new 18x8 rims will be .4724 inches closer to the fender filling the gap compared to stock and everything else remains the same. How many mm or inches can we extend closer to the fender without having to tuck or roll them in and also and how much mm or inches can we afford to go closer inwards to the strut housing before touching on a 2001 LS430 kept stock. Just want to find the safe zone.
Thanks for your knowledge and input mitsuguy.
Old 06-23-07, 11:25 AM
mitsuguy
mitsuguy's Avatar
all correct on the sizing (at least without doing it myself, it looks right)... Anyways, you can go a littler further, or even a lot further, but then tire size will come into play... I honestly don't have figures on the LS's as far as clearance, hopefully someone who has something similar will chime in here... On the inside, so long as you give yourself a half inch clearance between the shock and the wheel, you are good - you don't need a lot of room there...
Old 06-23-07, 11:45 AM
DanozLS430
DanozLS430's Avatar
Thanks for your input. I appreciate it.
Old 06-23-07, 12:01 PM
bb430
bb430's Avatar
My fronts are 19x9 44 offset which is 20mm more outward and are not rubbing with 245/40/19 w/Michelin PS2. My rears are 19x10 49 offset which is 28mm more outward and has no rubbing issue with 275/35/19 w/Michelin PS2. They do filled up the fender very fully and I don't need to roll or cut my fenderlip at all...Hope this help you and good luck...
Old 06-23-07, 12:08 PM
DanozLS430
DanozLS430's Avatar
Good input bb430. Would you say 28mm is about as far as you can go for the rears and 20mm for the fronts without rubbing? Did you go 20mm more outward on the fronts and not 28mm due to the tire size difference or because the fronts need more clearance?
Old 06-23-07, 12:20 PM
bb430
bb430's Avatar
To me, mine set up is about as tight as you can get w/o rolling/cutting fenders as far as I can see(I have UL w/stock ride height), I want stagger setup hence the front/rear differences.
Actually, the inside of the fronts are only about 3mm to the banana arm and the inside of the rears are touching the protecting boots of the air sacks. But they are fine this way to me as long as they don't touch anything metal or the fenderliner.
I wish I can show you w/pic. but I just don't get the upload procedures here, sorry....
Quick Reply: What offset is recommended for 18x8 0r 18.7.5 rims on 2001 LS430?
