Serpentine Belt? creaking in the morning after cold starts.....
Dealership told me why during the cold mornings after I start the car up, it is creaking and squeeking........
They told me it needs to be replaced?......anyone have this replaced before?
thanks.....
I just did it last week.
Go to AutoZone and get the Gatorback belt by GoodYear for less than $40.
Here is the link to the instruction.
If you have an Injen Intake, then it should take you less than 10 minutes to change the belt. haha
https://www.clublexus.com/forums/sho...ht=change+belt
wow!!!!!!
wow, only $40.00, I will definitely change it myself..... the Dealership quoted me $150.00 just on the belt alone, and I don't know the labor cost.....Thanks very much.....I will definitely PM if I run into trouble installing it myself? Does it require just loosing a "round pulley"....then attaching the belt?.....
thanks once again......
You can pm him if you don't understand anything I say.
GS400 and SC430 are the same, don't worry.
$150 just for the belt alone...that is crazy.
I spent less than 10 minutes on my SC430 the first try and then only 2 minutes on my brother-in-law's GS400.
Both cars have after-market intake, so it gave me enough room to access the belt area without removing anything.
You may need to remove part of your stock air box.
It is also easy and should take you less than 10 minutes.
The tool you will need to change the belt is 14mm socket and wrench.
This is what I used.
Push the wrench down to release the belt by turning the drive belt tensioner counterclockwise, and remove the belt as exactly shown in pic.
When you let go the wrench, the tensioner will go back to its original position.
You turn the drive belt tensioner counterclockwise again when you put the belt back.
A picture of the belt diagram should be found on the inside of the hood in case you forget how to put the belt back.
I had dealer replace it under warranty 2 yrs ago and it had lasted only 20k miles till I changed it again last week.
Fortunately, it is a cheap DIY fix. Much easier than taking off a wheel.
How do I remove the air boxes? is that difficult or just a few clips to remove?
If you have super big hands, then ask your wife/gf/kids to put the new belt back for you while you are holding the wrench.
I already forgot how the stock intake looks like.
You need to remove the air cleaner assy that holds the filter for sure.
If stock air inlet is getting ur way, remove it as well. Should be only a couple bolts and clips here and there.
Just play it around, you won't break anything.
While you are there, take some pics and share them with other members here.
Should I just get another one and put a new belt on at the same time. I have 35,000 miles on the car and this chripping has been going on for the last year or so. I drive the car very little, only about 1,200 miles in the last year. Could the sound only be the belt itself?
However, a new belt from the dealer shouldn't cost $150. Retail is only $47.08. Not sure how they can charge 3x the retail price.
