ES300: Replacing Cluster Backlighting Bulbs
Old Apr 10, 2007 | 03:23 PM
Lexucan's Avatar
Lexucan
Lexucanafer
Originally Posted by 92ES5sp
Thanx Lexucan! Um....here is my 100K photo which youve seen. So the backlights are incandescent bulbs and not LEDs right? Ill dim the brightness of my cluster to keep em going. Ill be referring to your DIY when the time comes, the red tips look badass!!
Yep, the backlights are just ordinary little incandescent bulbs but they can be replaced with LEDS too when it's necessary.
One day about a year ago or so my temp needle had a slow flicker to it, then it had a dead spot so I whacked it and theyve been fine!
You're lucky! Like I said before - pretty rare to have all four working in a 15 y.o. car!
Glad the whack job did the trick! (probably the easiest and cheapest DIY ever!) LOL
Dimming your display brightness should help to preserve them too.
Old Apr 10, 2007 | 04:04 PM
tuan92129's Avatar
tuan92129
Hha since some people still have working needles, I'll put more tips on keeping the needles alive longer
Heat, I read on Lextech is bad for Leds, especially in the Southern California sun. Use a windshield cover and if the top of the dash feels hot, then turn the needles down.
Get used to the fact that during the day, you don't really need to see your needles...I just turn them all off.. (my friend said it looked cool b/c it was blacked out lol )
Haha if you look on the first pg, i accidentally bought 10 led bulbs, so fortunately i found the white bulb that matched
Will post pics when it gets darker.
Old Apr 10, 2007 | 04:06 PM
Parker Gen's Avatar
Parker Gen
I'm soo confused... I've gone to all the motor acessories shops round here, and none of them have the 5mm 3W bulb for the backlghts. And none have LED's that can match the size of the original bulb. Do any of you have a link where you bought the LED's from so I can buy some?? My problem is shipping to Australia.
And another question. Did these LED's that you guys bought fit straight into the housing for the original bulb? No soldering needed?
Thanks.
P.S. I got chrome needles in my cluster :thumbs:
Pictures when I put it back into my car with new Backlights (That's all I'm waiting for now!!)
Old Apr 10, 2007 | 04:28 PM
tuan92129's Avatar
tuan92129
man!! you stole my idea
For during the day, I wanted to paint two strips on both sides of the red led part of the needle so it looks like this.. ======== <- during the day and -------- at night. the Mercedes c230 and 90's acura had the silver needles, so i think that would look cool.
Also for the backlighting leds..there is no direct led replacement for it that will fit 100%
However, the #74 bulb Lexucan recommended will work, but is somewhat loose b/c its a little thinner. I used electrical tape to stuff the extra space.
Link to ebay seller.
Shipping took 10 business days though, and I would order 10 bulbs just in case? if you search "74 led" you should come up with plenty of other sellers.
http://cgi.ebay.com/ebaymotors/2pcs-...spagenameZWDVW
Old Apr 10, 2007 | 04:39 PM
Parker Gen's Avatar
Parker Gen
HHAHA. Too bad bud.
I got to chuck some pictures up now, just to claim originalty
Oh... is that link where you bought yours from or???
Old Apr 10, 2007 | 06:06 PM
Lexucan's Avatar
Lexucan
Lexucanafer
Thanks.
I bought #286 5mm wedge-base white/blue flat top LEDs for my cluster backlights and they were the perfect size. I just took the old bulbs out of their sockets and popped the LEDs into the same sockets - no soldering involved. Getting flat-top LEDs is important b/c they throw light in more directions than the usual dome-top LEDs which produce only a narrow beam of light.
Here is the item number for a current ebay listing for this type of LED
Item number: 200098292944
Old Apr 10, 2007 | 07:26 PM
tuan92129's Avatar
tuan92129
No wonder the bulbs didn't fit perfectly..i needed #286 bulbs
???? I could have sworn i didn't see #286 bulb in the write-up last week??? lol
Old Apr 10, 2007 | 08:23 PM
Ariyanna's Avatar
Ariyanna
This is what your cluster should really look like, try installing 64 Super Bright LEDS in the cluster and this is what u get. Took me 8 hours to complete and calibrate.
Attached Thumbnails ES300: Replacing Cluster Backlighting Bulbs-picture-20071-20-28800-20x-20600-29.jpg
Old Apr 10, 2007 | 08:43 PM
tuan92129's Avatar
tuan92129
Let us in on the secret
Although 64 leds is kind of excessive..
maybe 18 leds would be a better compromise..
hmm..I wonder if you can fit a couple of led strings or something similar inbetween the back of the circuit board and the face plate?
Old Apr 11, 2007 | 08:50 AM
Slooooooow's Avatar
Slooooooow
Regional Officer - NTL
Question
I don't get it.
Remove the old bulbs.
Insert the LEDs in their place.
What's to calibrate? Why 8 hours?
Looks GREAT btw!
Old Apr 11, 2007 | 09:02 AM
Lexucan's Avatar
Lexucan
Lexucanafer
Originally Posted by Slooooooow
I don't get it.
I've been wondering the same thing.
I guess putting in 8 times as many LEDs as there were original bulbs might take a while longer (maybe they are the type that incorporate multiple LEDs into one light?) but what needs calibrating?
You might need sunglasses at night to read the gauges without being blinded by the light from the cluster
Old Apr 11, 2007 | 04:25 PM
tuan92129's Avatar
tuan92129
I think Ariyanna customized the unit to work with 64 leds?
I know lextech offers this service where they modify the rear to add 1 led under each number.
Old Apr 11, 2007 | 04:33 PM
Parker Gen's Avatar
Parker Gen
I think the question I'm in need of is... "Why would you??" Other than that, looks good, but maybe a little over the top.
Old Apr 11, 2007 | 05:38 PM
Lexucan's Avatar
Lexucan
Lexucanafer
If that was the case, it would only require 20 or so LEDS, not 64 of them
Old Apr 11, 2007 | 06:37 PM
tuan92129's Avatar
tuan92129
Thats why Lextech offers a 64 led conversion
