TPMS compatibility question????
Old Mar 13, 2007 | 11:43 AM
Phanatik's Avatar
Phanatik
Default TPMS compatibility question????
Is there any way (modifications) to make non-compatible wheels compatible? If not, is there any way to disable the sensors or to make the warning light go away and just not use them anymore? I tried searching for some info on this but couldn't find a definite answer. Thanks a lot in advance.
sinister2c's Avatar
sinister2c
barrel bands to strap the sensor inside the wheels.
Old Mar 13, 2007 | 11:48 AM
menech's Avatar
menech
Any good wheel shop can drill a second "dummy" valve stem hole in the wheel to mount just the sensor.
Old Mar 13, 2007 | 04:09 PM
Phanatik's Avatar
Phanatik
So if you drill a second "dummy" valve stem hole in the wheel to mount just the sensor, then the sensor would work perfectly? Is that all they have to do? Would the wheel shops do that?
tucker21
May 19, 2016 05:26 PM
BieberNutz
Wheels, Tires & Brakes Forum
Jan 1, 2016 01:03 PM
CharlieVo
Mar 23, 2014 08:39 PM
revspeed
Sep 13, 2006 12:52 PM
zerohero
17
May 17, 2006 05:41 AM
