What are size bulbs do I need for everything?
Old 03-02-07, 02:43 PM
Burst32
Burst32's Avatar
Default What are size bulbs do I need for everything?
First off, will someone tell me how bright the stock HID's are. I have the AFS system so I dont know if that changes anything. I would like to install brighter lights in the HID lows, the highs, and the fog lights. But i dont feel like tearing **** open to look. my car goes in next week and I can have them install the aftermarket lights. PLEASE HELP. thanks...
Old 03-02-07, 05:03 PM
Nuster
Nuster's Avatar
2006 LEXUS IS250, IS350 (With replaceable halogen capsules)
Low beam headlamp
H11-55W (Halogen, not HID)
D4S (Stock HID bulb size)
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Glove box
37
Dome light
DE3175
Step/Courtesy light
194
Trunk/Cargo area
DE3022
Old 03-05-07, 03:41 PM
Burst32
Burst32's Avatar
Thankk you
Old 03-30-07, 12:41 AM
Jay.Diem
Jay.Diem's Avatar
When getting aftermarket H11 HID bulbs, which of the following bulbs would fit best in the 2IS?
Note the 90 degree angle of the bulb, and the metal grooves ....
OR
Note the plastic grooves and straight connector.
When removing the stock H11 bulbs, which of the above two types did it resemble?
If you have the second type of bulb, did you have any trouble installing it?
Thanks.
Old 03-31-07, 05:40 PM
Jay.Diem
Jay.Diem's Avatar
bump ^^ ... any help would be appreciated .. don't want to buy the wrong type.
Old 04-05-07, 06:42 PM
ben_r_
ben_r_'s Avatar
So let me ask this... the red lights in the inner front door panel, is that light cover actually red, or is it just the light? I want to make it blue...
Old 12-18-10, 08:38 AM
intellis
intellis's Avatar
Low beam headlamp
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Glove box
37
Dome light
DE3175
Step/Courtesy light
194
Trunk/Cargo area
DE3022
Is this information the same for the 2007 350? My bulb just went out
Old 12-18-10, 10:26 AM
edgeucated
edgeucated's Avatar
I believe the cover is red. You can buy clear covers for pretty cheap and install whatever color bulbs you want
the information should be exactly the same. Use this site if you want to be sure, it also tells you stuff for any other car you want
http://www.sylvania.com/ConsumerProd...de/default.htm
Old 12-18-10, 11:27 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Sewell (vendor on here) sells the clear lenses for the doors. Sign up to be a member to receive a discount.
Old 06-21-12, 06:44 PM
silvaIS
silvaIS's Avatar
Default Help with bulb issue
Front Turn Signal Light Bulb Size: 992 (7440A)
Rear Turn Signal Light Bulb Size: 7440
IT LOOKS LIKE THE SAME BULB FOR FRONT AND REAR ON 2011 IS250
IS THAT THE CASE?
Old 06-21-12, 08:20 PM
my1s250
my1s250's Avatar
can we just install the can-bus LED used for European car would that stop the hyper blinking? or do we need the module?
Old 03-03-13, 05:01 AM
bduboulay
bduboulay's Avatar
Some good information here to have.
Old 03-19-14, 08:34 AM
sm1ke
sm1ke's Avatar
Sorry to bump this back to life..
How many turn signal bulbs are there for the headlights? 2 per headlight? Need to know right away
Old 03-19-14, 09:10 AM
dannyboy26
dannyboy26's Avatar
Originally Posted by sm1ke
Sorry to bump this back to life.. How many turn signal bulbs are there for the headlights? 2 per headlight? Need to know right away
You have two per headlight, but you have to remove bumper and headlight to get to them
Old 12-28-14, 03:12 PM
Makintoshe
Makintoshe's Avatar
Hye I was just wondering the the D4S bulbs are 35 Watt or 55 Watt
Low beam headlamp
High beam headlamp
9005
Parking light
168
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
9006
License plate
168
Back up light
921
Front sidemarker
194
Rear sidemarker
194
Glove box
37
Dome light
DE3175
Step/Courtesy light
194
Trunk/Cargo area
DE3022
Quick Reply: What are size bulbs do I need for everything?
