How much Money have you put in for Maint
Old Feb 14, 2007 | 06:47 PM
GKLCPA's Avatar
GKLCPA
Damon,
How much did you spend?
Old Feb 14, 2007 | 11:41 PM
damon's Avatar
damon
I would have to go back thru & ballpark this.
I bought all the parts as cheaply as I could & do what I can myself. I have an excellent independent mechanic who helps me keep cost down.
Of all the work done only the alignment was at a dealer. The EGR pipe replacement is an excellent example of where the CL Forum has helped me save money. My total cost to replace that was around $100.00 or so (cost of the part). At a dealer you can spend $1000.00
Same applies to fixing your intermittent gauges.
2 Important notes. My goal since getting the vehicle was to have a nice driving vehicle until it hopefully reaches the 300K mark.
Of all the work listed in my post the only time the vehicle was inoperable was when the fan bracket support bearing failed. Had every piece listed on my TB change in a bag in my trunk but that damn thing, so I was well prepared.
Every bit of the maintenance I have done other than this has been preventative or performance oriented.
I feel very fortunate not to have gotten bit by any AC system systems issues. This cost big bucks on my fathers 90LS.
Old Feb 28, 2007 | 03:00 PM
EastWind's Avatar
EastWind
Of all the work listed in my post the only time the vehicle was inoperable was when the fan bracket support bearing failed. Had every piece listed on my TB change in a bag in mt trunk but that damn thing so I was well prepared. Every bit of the maintenance I have done other than this has been preventative.
I feel very fortunate not to have gotten bit by the AC system.
wow, where did you buy all those parts? I am thinking about doing my timing belt and water pump, i figure maybe i should change a few of those along the way. what's the fan bracket support bearing? should i change it when i do the timing belt and water pump too? i think i have seen a thread about it. i am in michigan, and if i can have it my way, i will put 50,000 miles on this car this year, cuz I will drive it from here to Cali and back and all states in between. so I need it in solid shape. where did you get your parts again? thanks!
Old Feb 28, 2007 | 11:22 PM
Mobstar's Avatar
Mobstar
Originally Posted by uncle_el
bought the car a year ago with 149k, thought it was well maintained by an old couple in santa monica... little did i know that it wasn't.
6465.69 in one year, not including aftermarket parts.
dang that sucks. i could totally buy a new one with that.
Old Mar 3, 2007 | 06:59 PM
Harky's Avatar
Harky
I bought my '96 3 years ago with 57K on it. It had a new battery, tires and brake pads per PO.
I've put an additional 50K on it. I have not had a breakdown that left me stranded or the car un-driveable. I've not thrown any OBD codes. I think that's pretty commendable of the car.
I've done all of the filter and fluid changes per schedule myself - probably spent about $150.
New tires - $350
New brake pads and rotors - $400
New plugs - $25
New fan clutch - $60
New trut rods - $200
New tranny mount - $30
I've carefully inspected the TB and it looks good.
No coolant loss, no oil loss, but...Small PS fluid leak (typical) - I'm still trying to track down the source. It could be a hose ($200), the rack ($800), or the pump ($50 for seal kit). At this point, it's just a nuisance...takes a little ATF every couple of weeks.
So at this point, I've blown a little over $1200 in part + $0 on dealer/indie labor. Not too bad for such a nice car.
Old Mar 4, 2007 | 01:00 PM
puddintane's Avatar
puddintane
66825 miles cost per mile 99 LS
$938.00 0.0140 Registration
$28,070.00 0.4201 Lease Pmts
$33,763.75 0.5053 Purchase
$2,145.81 0.0321 Sales Tax
$2,000.00 0.0299 Ext Warranty
$418.00 0.0063 Interest
$12,610.52 0.1887 Insurance
$6,411.62 0.0959 Gas
$712.66 0.0107 Oil
$1,736.39 0.0260 Mainten
$1,305.82 0.0195 Tires
$1,893.25 0.0283 Repairs
$685.95 0.0103 Wash
$58.08 0.0009 Eqpt
$971.50 0.0145 tolls/park
($4,679.98) -0.0700 Tax Ret(used for business)
$82,688.19 Total
Old Mar 4, 2007 | 02:57 PM
Broker404's Avatar
Broker404
CL Folding 1,000,000
99 LS400, bought over a year ago, and done nothing but change the oil in 13k miles. Now at 123k.
Old Jul 17, 2009 | 04:16 PM
damon's Avatar
damon
Thought I would revive this.
I had years where I did quite a bit of maintenance because my goal was to hold the car long term.
From 06/03/2008 until today 07/17/2009 I have replaced:
Battery terminals
Added Freon & BG Frigi-Quiet
New Spark Plug Wires
Fuel Filter & temp sensor
Oil & Filter changes
Less than $300.00 total so I would say that I have been rewarded for my earlier efforts.
Old Jul 17, 2009 | 07:51 PM
BLKonBLK98's Avatar
BLKonBLK98
had my 92 for a couple months:
ps pump - $75
ho alt - $200
climate control - $100
mobil1 atf, oil change, and misc - $100ish
mbq sub - $60
new window switches - $70
Old Jul 19, 2009 | 01:46 AM
whysub's Avatar
whysub
Only just picked mine up, but I chose it because it had full service, cambelt & water pump change and an aircon regas in the last 2,000 miles. Suspension and joints overhauled 10,000 miles ago.
Now on 221,000 miles and feels like it has dne nothing like it.
Old Jul 19, 2009 | 11:05 AM
dsabc2867's Avatar
dsabc2867
i bought my 92 ls400 a year ago for 1500$. its done pretty well up until now. first thing that happened was that the idler pulley seized then it was the tensioner pulley. Both repairs ran me about 280$, oil changes are 11$ and it looks like im about to drop $1000 for an overhaul.
Old Oct 26, 2009 | 06:04 PM
Thermactor's Avatar
Thermactor
When I first bought my '96 in 2006 I spent about $700 in parts for it. Some of those parts got stolen. Later on I bought another $400 worth of parts for it that I hadn't yet installed.
The '95 I just bought two weeks ago has already burned straight through $1100 and there's another $800 left to go.
Old Oct 26, 2009 | 11:16 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
hey what's the color code on your 95?
Old Oct 27, 2009 | 02:30 PM
Thermactor's Avatar
Thermactor
6N9 which corresponds with "Ebony Teal Pearl", the kind of car you seem to have had.
Old Oct 27, 2009 | 03:35 PM
PureDrifter
BahHumBug
CL Folding 100,000
congrats you're the first person other than myself who i've heard of even having that color
pics nao!!
