Navigation Hack Alternative - Hybrid Nav DVD
This is to allow upgrade and keep the override function and NOT for discussion of copying the Nav DVD. You can purchase your DVD upgrade from your local dealer or get a better deal from our CL vendors such as Sewell Lexus / Lexus parts here.
BACKGROUND INFORMATION:
2006 ISx50 = V5.1 DVD Navigation disc = V1550 firmware = Override Exists
2007 ISx50 = V6.1 DVD Navigation disc = V1650 firmware = NO Known Override Exists
FACT #1:
Upon inserting the V6.1 DVD into an ISx50, the firmware will be AUTOMATICALLY updated to V1650. Hence, you will lose your override.
FACT #2:
It is possible to go back to the old firmware. Yes, you heard me right. You can go back to your old firmware. It is NOT a problem at all, despite what Lexus and others may tell you. All you need to do is remove the fuse for the nav unit and put the old V5.1 disc back in. It may take 1-2 attempts, but the nav unit will load the old firmware with no problems. Many of us have gone back and forth between numerous firmwares on the ISx50 without any problems whatsoever.
FACT #3:
The firmware file is located on the nav DVD and is called "loading.kwi". This is only loaded when the power is cut to the nav, or a newer firmware is detected.
SOLUTION TO OVERRIDE:
You will need to own BOTH discs (V5.1 and V6.1) and a PC with a DVD Dual-Layer burner that supports bitsetting (booktype) in order to do this.
1) Copy all the files from the V6.1 disc to your hard drive into a directory called "nav" (or whatever name you want)
2) Copy the loading.kwi file from the V5.1 disc to your hard drive into the same "nav" directory, overwriting the existing loading.kwi file
3) Burn all the files in the nav disc directory to a DVD+R DL disc - Booking type (bitsetting) DVD-ROM
You now have a DVD with all the map data and new features of the V6.1 disc, with the firmware + override of the V5.1 disc.
This has been confirmed to work on an ISx50.
The biggest variable here is your burner software settings, although many variables exists, including what type of media you use, what burning software you use and the type of burner you have.
FYI, our successful burns used:
1) Various media (Verbatim and Memorex)
2) Various burning software (dvd decrypter, isoburn, or Prassi Ones)
3) Various burners (plextor, benq, samsung, liteon)
4) Burner software settings must set - Book Type (aka Bitsetting) = DVD-ROM
Hope this helps those of you who wanted to upgrade to the new V6.1 DVD but don't want to lose the override.
"Pro-Override gang" signing off...
Here in Calgary, Canada I can tell you that the map information is not much different than the map information on the 5.1 disk. To be honest with you the map information is quite poor in comparison to my friends portable Garmin unit.
2) Burn DVD (20-30 minutes)
3) Eject old DVD and replace with new burned DVD (5 minutes)
4) Pull fuse and replace and watch firmware load (5-10 minutes)
So maybe like 30-60 minutes...
Do we just have to eject the 6.1 DVD and copy the contents to our hard drive, replace the loading.kwi file with that from the 5.1 DVD, burn it all to a DVD+RL disc (bitsetting to dvd-rom), and then just insert it back into our car and let it do it's thing? In other words, for those with an 07 all they really need is the old firmware file?
One other question, which I'm sure has been answered before but would be nice if it was in this thread. How/where do we eject the dvd and insert the new one we made.
Thanks
Thanks
A reminder that discussion of software piracy on our forum will result in infractions, suspension or permanent removal of your access.
I have removed a couple of posts already that, if continued, will cause this informational post to be closed.
https://www.clublexus.com/forums/faq.php
Specifically
https://www.clublexus.com/forums/faq...hibited_topics
The following topics and links are prohibited on Club Lexus:
Links or discussions regarding software piracy including duplication of Lexus Navigation DVDs or other Lexus software
A) Own both disks versions, creating a workaround for the Override FINE, NO PROBLEM
Questions about the process on creating this type of hybrid backup JUST FINE
B) Discussions about swapping disks between members, burning and /or selling Nav DVD copies, sending files YOU WILL BE SUSPENDED
There will be no further warnings in this thread on this topic. Post about piracy, you will take two weeks off.
PS, nice job Technique
Are you sure you can go back and forth with the firmware? I know maybe the version number on the screen might change or maybe it appears that the [re]loading is taking place (which in and of instead is not exactly proof) but are you absolutely sure that the old firmware is put back into the nav? What is different about the old firmware vs. the new firmware (functionality, color, routing, new screens, etc) that proves the new firmaware is removed and reverts back to the old firmware?
I'm asking for those of us with '06 who screw up this conversion and want to simply start over and go back to the old '06 disc and firmware and get the old override back, are you 100% positive?
