Dumb Question How to turn off the daytime running lights on an 01 GS430
Old 04-01-05, 07:21 AM
achadha100
achadha100's Avatar
Default Dumb Question How to turn off the daytime running lights on an 01 GS430
cant figure out how to turn it off i see other GS's with them off thanks
Old 04-01-05, 07:36 AM
Motu1
Motu1's Avatar
I think it may be bulb specific. I just bought some new bulbs(Sylvania) and now they are on all the time. The originals were not on.
chicagoblknazn
chicagoblknazn's Avatar
Take out the bulbs
Old 04-01-05, 08:12 AM
GS300Rich
GS300Rich's Avatar
Or you can put in one burned out bulb, if you take the bulbs out is there some kind of warning that will go off?
Old 04-01-05, 08:15 AM
Kbueno
Kbueno's Avatar
Try and do a search, there is a thread on how to disable them...it involves creating a jumper wire within the fuse box.
Old 04-01-05, 08:38 AM
2KGS400
2KGS400's Avatar
Take out the bulb=no more high beams.
There's a recent thread (I think by BananaGS?)that describes how to do it. All you do is remove a "jumper" in one of the fuse/relay boxes.
J.
Old 04-01-05, 09:21 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
bananags has a diy but i think his site is down there. it's some fuse that you take out.
98 doesn't have drl, and it started on 99. my 98 doesn't have it
Howells (02-02-18)
Old 10-10-06, 02:48 PM
mvallido
mvallido's Avatar
Take it to the dealer and have them turn it off.
Old 10-10-06, 03:37 PM
Kbueno
Kbueno's Avatar
Found it..here:
https://www.clublexus.com/forums/sho...ght=drl+defeat
Old 11-16-06, 05:35 AM
BossGS4
BossGS4's Avatar
This is on my '01 GS430
NOTE: The left side has the 'tab' removed as you really have to wedge it into the holder with the DRL #1 minifuse
Drum roll please ..............
Presto .... NO MORE DAMN DRLs now I can put ANY 9005 bulb in there that I want (i.e. Toshiba HIR @ $30) without fear of blowing them early due to being on 90% of the time at half wattage.
n1ck (05-19-18)
Old 11-16-06, 12:33 PM
ElitistK
ElitistK's Avatar
...but i thought our DRLs have bulbs seperate from the high beams? How come i see 2 more bulbs inside the high beam housing?
Old 11-16-06, 02:14 PM
BossGS4
BossGS4's Avatar
Daytime Running Light = High Beam Lamp @ half voltage
The smaller bulb you see in the High beam housing is what's commonly referred to as the wedge light or city light . This small bulb only comes on with your low beams.
Old 11-16-06, 08:23 PM
enjun
enjun's Avatar
what gauge of wire should I use.
Old 11-16-06, 08:53 PM
BossGS4
BossGS4's Avatar
I used some plain 12 copper strand wire, 16 ga
Old 11-17-06, 05:25 PM
GSXOTIC
GSXOTIC's Avatar
Where can i get this?
Quick Reply: Dumb Question How to turn off the daytime running lights on an 01 GS430
