Labor estimate for starter replacement on '94 ls400...
Old 10-02-06, 07:13 AM
youforia
youforia's Avatar
Default Labor estimate for starter replacement on '94 ls400...
Just got an estimate for the labor on a starter replacement for my Lexus LS400 from a local independent shop which I've worked with before. They quoted me $430 for the labor. Does that sound reasonable? Thanks!
Old 10-02-06, 01:40 PM
takumi117
takumi117's Avatar
Yup that sounds just about right, an arm and a leg for a new starter and labor... The starters in a hard place to get which means taking of the intake manifold and such.
Old 10-03-06, 09:08 PM
Lextreme
Lextreme's Avatar
normally it will take 5-6 hours. You can do it yourself and save bunch of money. It quite simple.
Old 10-04-06, 12:28 AM
takumi117
takumi117's Avatar
How simple is it? Do you just take apart the intake and manifold and it should be right under that? Or more things are needed to take off. If it's that easy i would do it to save on labor.
Old 10-04-06, 08:46 AM
lorenzo816
lorenzo816's Avatar
Default Look here
In August, we went over this.
Read here and here
Good luck.
Old 10-04-06, 09:14 AM
dfkd
dfkd's Avatar
THERE YOU GO
I can post the procedures is you want to try it yourself.
Old 10-04-06, 11:53 PM
Lextreme
Lextreme's Avatar
Its time consuming but not hard.
Old 10-05-06, 04:59 PM
takumi117
takumi117's Avatar
Read here and here
Good luck
WOW That's a lot of reading there... Thanks for the thread , ill read up on it.
Old 10-12-06, 11:46 AM
HMCGARY
HMCGARY's Avatar
Try a few Lexus dealerships in your area because I got wide range of prices from 450 to 800 but i do live in Chicago.
Old 10-12-06, 11:54 AM
GSteg
GSteg's Avatar
my local mechanic shop did my GS400 (same procedure) for $600 and that's including a brand new starter from lexus so labor was about $300 ($50/hr). Shop around and you'll eventually find a good price, but $430 is reasonable.
Old 10-13-06, 08:45 AM
persian451
persian451's Avatar
You have to replace a lot of seals as well.. I would reccomend fixing the rear main seal while you are there and having the EGR pipe inspected. Both of these items are issues that you might have or will have in the future. So you might as well have it done then since they are charging you for labor accessing that area.
Superfast1
09-19-19 09:12 AM
skperformance
06-09-09 10:05 AM
dinh626
12-19-06 06:10 PM
thailegend
04-02-06 10:24 PM
Evillex
04-25-04 09:39 AM
Quick Reply: Labor estimate for starter replacement on '94 ls400...
