Aftermarket Sound System Owners Post Your Setup!
Old Sep 28, 2006 | 04:50 AM
  #61
MrMark's Avatar
MrMark
Originally Posted by Kepeli
I want one of these....
I'm wondering where the vent is.....
Old Sep 28, 2006 | 05:09 AM
  #62
Technique's Avatar
Technique
CL Folding 500,000
Originally Posted by AZ IS350
I don't think JL allows authorized dealers to sell online. Of course you can probably find it online somewhere, but JL will not honor the warranty. I'd say you can't go wrong with Crutchfield online. Not the best prices, but reputable and they have tons of good information and excellent customer service. Lots of other sites out there, but your mileage may vary with them.
Unfortunately, I don't believe Crutchfield sells JL Audio... I guess I'll just go with ebay...
Old Oct 30, 2006 | 04:56 AM
  #63
albatrozz's Avatar
albatrozz
Try http://www.sonicelectronix.com
10" JL Subs
12" JL Subs
JL Amps
Word of warning: They took FOREVER (10 days after payment) to ship my order, but most people don't seem to have problems, so YMMV. They also sell on eBay and have decent feedback (except from me). Nonetheless, their prices are right, and they did ship the product eventually.. I'd do business again.
Old Oct 31, 2006 | 08:35 PM
  #64
Kuki_350's Avatar
Kuki_350
Originally Posted by cmusic
Factory CD indash changer moved to the glovebox
Head unit: Alpine F#1 Status CDA-7990
Sound processor: Alpine F#1 Status PXA-H900
Amplifier #1: Alpine MRV-F545 (front doors and sub)
Amplifier #2: Alpine 30x2 (center channel)
Front door speakers: Boston Acoustics Z6 6.5”mid and tweeter
Center Channel: Tang-Band W3-315 3” full range mid
Subwoofer: Alpine Type-X SWX-1042D 10” sub
Wiring and electrical accessories: Stinger
Future upgrades:
Finish trim around head unit
Add Brax X2400 amp to bi-amp Z6 speakers
Redo trunk installation
Add rear door component speakers for full 5.1 setup
Add Alpine DHA-S680 6-disk DVD changer
Upgrade battery
Hey CMUSIC,
If i want to install a sub, are these the accessories that i need?
Stinger Amp Kit Includes:
18 ft. - 4 Gauge Red Custom Pro Power Wire
3 ft. - 4 Gauge Black Custom Pro Ground Wire
17 ft. - 18 Gauge Blue Remote Turn-On Wire
1 – 24kt Gold Plated ANL Fuseholder with Mounting Screws
1 - 150 Amp ANL Fuse
1 - Custom Pro 4 Gauge Ground Lug
Assorted Ring Terminals, Spade Lugs, Butt Connectors, and a Plastic Grommet
7" Black Wire Ties """"
and
Stinger Expert Series SX17 Interconnect Signal Cable i.e RCA connects?
Please let me know what else i need for my setup.
Thanks
Old Nov 1, 2006 | 04:57 AM
  #65
cmusic's Avatar
cmusic
Originally Posted by Kuki_350
Hey CMUSIC,
and
Thanks
You also need a speaker to RCA line output convertor (LOC) if the amp you are using does not have speaker level inputs. I like David Navone products. The NE-7V would work well in the IS's audio system. http://www.davidnavone.com/adaptor_products.htm
Everything else you listed looks good.
Old Nov 1, 2006 | 05:30 AM
  #66
Kuki_350's Avatar
Kuki_350
I have a Rockford Fostgate T10001 Power amp running a JL audio 8W7. So i don't know if my amp has the speaker levels inputs or not. What does the SLI do anyways?
Old Nov 1, 2006 | 07:09 AM
  #67
cmusic's Avatar
cmusic
The RF amp you have does not have speaker level inputs. It has RCA inputs and can only handle probably up to 8 or 9 volts of audio signal. The factory amp speaker outputs carry 20-25 volts to the speaker. The LOC lowers the voltage down to a level so the RCA inputs won't be damaged by too much voltage.
What is an SLI?
I had an 8W7 and blew it with a 600 watt amp. So be careful with that 1000 watt amp powering the 8W7.
Old Nov 1, 2006 | 05:09 PM
  #68
Kuki_350's Avatar
Kuki_350
What is an SLI?
I am thinking of getting a JL audio 500/1 or 250/1. Do these amps has the speaker level inputs? Btw, SLI=speaker level inputs. Also, i noticed that you took out your stock sub to enhance your aftermarket sub sound, so my question is will you be able to put back your stock sub if you so choose later on? Thanks for you fast and helpful response. Kuki
Old Nov 2, 2006 | 05:01 AM
  #69
cmusic's Avatar
cmusic
Both the 500/1 and 250/1 can accept speaker level inputs. You flip a switch on the amp near the RCA inputs and then plug in a pair of RCA cables that have been connected to the factory amp's sub wires. BTW, on their website JL Audio recommends the 250/1 to be used with a single 8W7.
And yes, I can re-install the factory sub as it came from the factory. It just bolts in place and the wiring plugs into it.
Old Nov 2, 2006 | 08:33 AM
  #70
korean32's Avatar
korean32
Default MY Setup
Jl Audio 500/1
(2)jl Audio 10w7 Subs
Old Nov 2, 2006 | 08:38 AM
  #71
Technique's Avatar
Technique
CL Folding 500,000
korean32: Those subs are W7? I thought they were W3...
Old Nov 2, 2006 | 03:07 PM
  #72
ItalianLex's Avatar
ItalianLex
Originally Posted by korean32
Attachment 93608
Jl Audio 500/1
how does that sound??? That set up is nice. Also do you have the ML or regular audio package?
is it worth it to get the ML package if you're thinking about getting a sub or 2 installed?
Old Nov 4, 2006 | 04:52 PM
  #73
albatrozz's Avatar
albatrozz
Attachment 93608
Jl Audio 500/1
Only using 1 amp? Can't those 10w7s handle 500W each? Probably overkill to use 2, but why not just use 1 speaker then?
Old Nov 5, 2006 | 07:09 AM
  #74
cmusic's Avatar
cmusic
Jl Audio 500/1
I've owned W7 subs. Those are not W7s in the picture.
This is a 10W7 sub:
Old Nov 5, 2006 | 11:10 AM
  #75
Technique's Avatar
Technique
CL Folding 500,000
hehe, is there an echo in here??? Look a few posts up, from a few days ago, I already posted that those look like W3's, even though the OP never responded... His sig is obviously incorrect...
