SC- 1st Gen (1992-2000)
How many people have non working factory keyless entry?
Old 08-19-06, 07:58 PM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
Default How many people have non working factory keyless entry?
I'm about to dig deeper into the Sc wiring than we've seen in DIY's and need to know how many suffer problems with the factory keyless.
If you've replaced your battery and it still doesn't work, post here. This DIY will have a pictorial walking you through the proper checkpoints, wires, and items to check. Where to probe for voltage, WHAT to probe for voltage, resistance, etc.....
This is a really big task, so I need to know how many people need it. When I am done with the DIY, you will be able to diagnose and fix your keyless system in about 30 minutes.
The DIY will include pics, writeup, explanations, measurements of resistance, voltage, circuits, and anything else related to the keyless system.
Post here if your keyless is on the fritz.
Old 08-19-06, 07:59 PM
kietlander
kietlander's Avatar
mine still works
Old 08-19-06, 08:00 PM
eskinol
eskinol's Avatar
Plus 1 here. (As in not working)
-esk
Old 08-19-06, 08:04 PM
np20412
np20412's Avatar
Mine doesn't work. I've replaced the battery several times, made sure the switch is set to ON, still no dice. It hasn't worked at all since I've owned the car.
1994 SC300
Old 08-19-06, 08:07 PM
DriftNsc3
DriftNsc3's Avatar
After putting new batteries in it works for about a day or two if i'm lucky. So I guess I have wiring problems too.
Old 08-19-06, 09:00 PM
Sweetser
Sweetser's Avatar
I just put new batteries in, but the only way mine would work is I have to place the key right next to the door handle and push and hold the button down. Sometimes if I don't place the key in the right spot and I push the button down, it doesn't open...then when I push the button down again it won't work - so I end up using the key.
Old 08-20-06, 01:05 AM
SCSJ
SCSJ's Avatar
Mine work, but i have to be close to the car, and also it only works most of the time
Old 08-20-06, 01:20 AM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Ditto here, i have the crappy little button on the key that has to be facing the car and no more than 5 to 10 feet away in order to register.....really crappy keyless entry if you ask me, but i guess for a 14 year old car i say its doing just fine....
Old 08-20-06, 01:42 AM
dinhNER
dinhNER's Avatar
mine still work !
( get clifford and stick your key into the clifford/viper shell )
Old 08-20-06, 01:53 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
the people that have SOME range need to open the transmitter and resolder the antenna connection. The solder breaks off the end of the key (which is the antenna).
for people who have non working keyless, put a fresh battery in and tune your radio to 94.9 fm and press the side of the key button for keyless operation. listen for a reaction.
Old 08-20-06, 03:33 AM
bigmalik00
bigmalik00's Avatar
that is just it.. my doesn't work but I heard the radio had something to do with it. I took my factory radio out.
Old 08-20-06, 05:00 AM
O. L. T.
Keeper of the light
Forum Moderator
O. L. T.'s Avatar
for people who have non working keyless, put a fresh battery in and tune your radio to 94.9 fm and press the side key. listen for a reaction.
Old 08-20-06, 07:06 AM
Danimal
Danimal's Avatar
Mine works sometimes with limited range, sometimes not at all. And OLT, you da man.
Old 08-20-06, 07:35 AM
stonewis
stonewis's Avatar
What remote? Mine is a 92 and the local (85 miles away!) dealer said it's a "Gulf States" SC400 and a remote is not available...nevermind that there's an on/off switch under the dash that says "remote". Anyway, this forum has been a big help and I know what I need to buy to get it to work. Now, to find the items I need!
My first post!!!
PS I just got the car last week and can't stop driving it! What a f/n blast! I hope I don't get a speeding ticket!
Old 08-20-06, 09:26 AM
Hai_Nguyen
Hai_Nguyen's Avatar
mine worked on both my SC's. Range kinda sucks on my current one.
OLT, awesome information! I'll have to check that out.
I also heard that putting your key up to your head helps increase the range.. Never tried it before though. My 95 made a beeping sound when locked/unlocked but my 94 doesnt make any sound.
Quick Reply: How many people have non working factory keyless entry?
