toyomoto Manifold
Old Mar 8, 2001 | 08:45 AM
SC300TURBO's Avatar
SC300TURBO
Just so you all know...toyomotos last sc300 they did with the T62 turbo laid down like 600 rear wheel hp with the cast iron manifold....so it flows plenty...had mine for 2years now with no problems.....as far as the heads...toyomoto is using a 2JZ-GE motor in his drag car...fun fun....Jeff
Old Mar 8, 2001 | 11:45 AM
JBrady's Avatar
JBrady
Wow, 600rwhp with a 62-1. Is this confirmed or rumor? The compressor map for the 62-1 show the PEAK possible output to be apx 70lbs of air/min. Lbs of air/min times 10 is about the power available. So this would mean 700hp MAX. Max at 15psi would be apx 600hp at 65% compressor efficiency (getting low and hot). At peak efficiency you have 450-475hp at 76% and 75% compressor efficiency respectably.
See map here: http://www.turbocharged.com/catalog/compmaps/Fig10.gif
BTW, the 60-1 peaks at apx 650hp but is more appropriate in the 500hp range. Max at 15psi and 65% efficiency would be apx 550hp. Remember these are flywheel numbers and you would need to subtract about 50hp for manual car and about 70hp for automatics for the rwhp number.
60-1 map here: http://www.turbocharged.com/catalog/compmaps/Fig9.gif
Old Mar 8, 2001 | 12:42 PM
Ebanks's Avatar
Ebanks
Thumbs up My Car.
Damn, 600+ RWHP on the 62 in nice....
We are hoping my car will do 650 RWHP on just the turbo, and I also have that 120 shot on the car, but we may jet it up to a 200 shot before the end of this season.
Honestly guys, I am dumping a lot of money into my car, and I will be lucky to get like 100 more RWHP than what I had before.... I mean, if I would have put the larger exhaust housing on the 60-1 and sprayed the 120 shot I could have been close to if not slightly over 650 RWHP, and now I am hoping to hit 750+ RWHP (although, that is not what I am expecting, that is what I am hoping for). Is it worth the extra $20kish I am dumping right now? To me it is...
I wanted a stainless header for one thing, and I am having to put a lot more money into a beefier tranny and engine management, but whether it is worth the cost is always up the individual. I like custom stuff, because I like being different
This post was really pointless, I just thought i would post what I had in my mind after reading all of this... Feel free to ignore it
-Ethan
Old Mar 8, 2001 | 12:46 PM
LexusRules's Avatar
LexusRules
Jbrady - You continue to amaze me
Scott - i think i'll learn my car inside and out within 4 years, so i should be able to do it myself, well with a couple buddies, and by then i hope to have an ultimate garage too.... okay thats a dream.... but i do!
Old Mar 8, 2001 | 07:27 PM
Snd Performance
Guest
Posts: n/a
Originally posted by SC300T
You'll need the Supra TT inline fuel pump. Unfortunately, you'll need a custom or TT? (don't know if the TT intake works on the NA head) intake system as well because the header puts the turbo high up in the way of the stock intake.
Actually the stock intake will work fine, the turbo is not in the way......... close, but it clears.
Lar
SP
Old Mar 9, 2001 | 10:37 AM
v300's Avatar
v300
Default VVT-i
Guys (with turbo upgrades),
Are your engines VVT-i or non VVT-i? Does Toyomoto or SP have a Turbo setup that works with the VVT-i based 2JZ-GEs? Hows your experiences with them? SC300T mentioned that going past 9psi would require sometype of Air-Fuel Regulator such as the A'Pexi S-AFC or HKS S-AFC. Is that enough for pushing say 1.4 bar (20psi) without a VPC? I was told that the VPC will not work on the VVT-i engines with the electronically controlled throttle and that I would have to wait for HKS new stand alone computer.
Now here's my dilemna: I converted my car into a Aristo V300 (stage one). Now I want to take another step by upgrading to a single turbo setup. I have a '00 2JZ-GTE w/ VVT-i and the V300's ECU, wiring harness, four speed tranny, Supra/Aristo Fuel Pump, Supra 550CC injectors, fuel return line, and upgraded to a single turbo utilizing a combination of Sard's stainless steel manifold, XS-Engineering's Garrett-based T04X (w/.70 A/R), HKS 50mm racegate with gate set at .6-1.0 bar, and a pretty buff GReddy FMIC. Problem is that I cannot get my hands on an upgraded ECU/program. I am waiting in line for a HKS F-Con Pro V stand-alone computer (however the damn thing has been recalled for the third time).
Along with a good boost controller (HKS EVC Pro) can I boost 1.4 bar safely without a program? The best thing (caveman) I can do is to obtain some type of air-fuel regulator such as the APex'i or HKS S-AFR.
What do you guys suggest? My goal is to put out 500 at the crank with room to upgrade in the future. My car ran fine as a left-hand drive V300 but I want more kick. Based on the similar Supra TT's stock fuel system (550cc injectors) and auto tranny what is a reliable hp output I might be able to utilize "reliably." I really appreciate the help.
Old Mar 11, 2001 | 06:08 AM
SC300TURBO's Avatar
SC300TURBO
Toyomoto has turboed several 2jz-ge vvti motors in the is300 and 99 gs300..he uses a haltech and has them running great with all daily driving handled fine...and it costs about the same as a VPC GCC combination....actually now that i think about it he put a hatech on a aristo motor that went into a lexus sc300 with a single upgrade so it can be done..give them a call 305-599-3050 Jeff
Old Mar 11, 2001 | 04:15 PM
v300's Avatar
v300
Default VPC can work w/ electronic throttle?
SC300turbo,
Thanks for your input. I have tried calling Toyomoto, but all I get is an answering machine. I hope the Haltech is what it is cracked up to be.
Old Mar 12, 2001 | 11:58 AM
SC300T's Avatar
SC300T
I've heard that the Haltech is pretty slick once it is working, but Warren Chang (A Supra owner and SupraForums.com moderator with the Haltech in his car) said its extremely difficult to install.
Old Mar 12, 2001 | 12:12 PM
Ebanks's Avatar
Ebanks
Scot-
I had heard the same thing about the Haltech.... I was told that for a daily driver it was definately not the management to go with, and that it was very difficult to get it running right.
I had heard things about cold startups not being all the smooth with the Haltech also....
Also, does the Haltech correct for altitude, temperature, etc.?
-Ethan
Old Mar 12, 2001 | 12:15 PM
v300's Avatar
v300
Default :(
SC300TURBO,
I just spoke to Phil at Toyomoto. They have never had the oppurtunity to work on that engine according to Phil. He also said that they have not been able to put a VPC on obd-II engines.
Old Mar 12, 2001 | 12:23 PM
SC300T's Avatar
SC300T
Ethan,
Any ideas how much SP would charge for just the HKS VPC GCC + installation?
I'm really considering this route as a first step at controlling fuel, but want to go with a shop that has done it before.
How have your experiences been with SP?
P.S.
Just passed 4k miles since the N/A to T60-1 conversion and all is bliss... Have driven in virtually every condition imaginable. Definitely a steetable setup and great as an every day driver.
Old Mar 12, 2001 | 01:39 PM
Ebanks's Avatar
Ebanks
Scott-
Im not sure how much Larry would charge honestly... The reason we didn't go with the VPC/GCC combo on my car is because you can't go larger than a 550cc injector that way, and that was not big enough for my needs.
2 or 3 weeks ago Larry told me that he had like 6 VPCs in stock, so you may want to drop him an e-mail and ask what kind of price it would be... His email is:
xxsupraxx@aol.com
BTW, you can go a LONG ways with the VPC/GCC setup... Larrys car is running that and look at his 1/4 mile time... On rough tuning!
Drop him an e-mail and let us know what he has to say about it!
-Ethan
02is3
Performance
Jun 16, 2016 05:13 PM
parnzen
Dec 3, 2007 11:09 AM
sphy1005
SC400 / 300 Classifieds
13
Mar 18, 2006 05:33 PM
Shellhouse
Dec 28, 2004 08:54 AM
