CA So. Cal fs. $320 shipped IS300 Front 17mm RCA's and Rear RCA's +- camber.
Selling a complete set of Front 17mm RCA's ($100) and Rear 44mm RCA's that allow for additional adjustable Negative camber ($220). Both will come complete with all needed hardware. $320.00 shipped for the complete set but can separate if only the front is needed to clear the Larger Calipers. This set can be used as a alternative to lowering springs such as I did with my car to maintain stock feel which I felt was already rather stiff or as a compliment to Coilovers.
Best part is it installs in less than an hour front and rear fully plug and play and easily removable with a few basic hand tools. Much quicker than replacing springs.. Pm me if interested or text me at 858-610-9100. Thanks
Pics of the drop you will receive if you are on factory springs and shocks.
My front has 23mm RCA's the 17mm pictured plus an additional 6mm from another camber adjuster plate/shim currently only used as a RCA
Full side shot.
Tires are 225/45/17 and Rear setting is for most positive camber possible. Next would be -2* and -3*.
The rear is still on my car and I'll remove it to take pics as soon as I get a chance. You can text me and I'll send pics there as soon as I get a chance.
Full side shot.
DiezDos
12-19-17 03:02 PM
ERICSC300
09-09-16 08:24 PM
