Alignment OK after installing Eibach Pro-Kit or Tanabe NF210?
Hello,
Seems to be a lot of posts about people dropping their IS's but I haven't read anything about any alignment issues. So those with the Eibach Pro-Kit or Tanabe NF210, were you able to get your alignment back within the specified range?
so you think the dealership will align after its been lowered? I don't think they'll want to touch it.
even if they do decide to do it, won't the OEM specs be wrong since the car is lowered?
Whether a dealership will work on a car with aftermarket parts varies. Some do and some won't. I can't say I blame the ones that don't as they may not want to deal with the possibility of sub-standard aftermarket parts, bad installs, etc.
In terms of the adjustability, there is usually a little adjustment available with the factory suspension pieces/parts. Much of it depends on the amount of drop.
Yup... I called 2 places, both said they didn't have the new books - whatever that means. One said he should be getting them in a couple of weeks - another whatever that means.
some dealers will align a vehicle the best they could. you can always adjust the toe back to factory specs. the difficult part is aligning the camber. most cars on the road do not have camber adjustments, so most shops will align the car to drive as straight as possible.
i have seen a fixed up LS400 at my local dealership getting alignment. it was fixed up VIP style with the wheels "poking" out. alignment is all labor, so if there is a problem, they just blame you for lowering your car and collect your money.
I work at an independent shop and it shows the specs for alignment for all wheels sizes ill make a copy of it tommorow and post it up. also can someone show me how to post pics that way i can just post up the pic of the whoel page.
i put air on my soon to be winter car and i just had it aligned to best as they can. this is a raceing shop and is good. i got my toe and canber fixed. but they cant ajust caster. but my car rides like it is on rails.
Alignment should be able to get back within factory ranges with the NF210. On an IS250 AWD, one Lexus dealership reported that front was able to be corrected within factory specs, and the rear was within a degree.
pr0vakativ, please do post that information! It will be a great help for the 2IS owners
It'd be interesting to see the tread life for the tires of these lowered IS's with these more agressive tire wheel combos and iffy alignments. Also don't forget that after a month or two when these new springs settle down your alignments will be off again.
