View Single Post
Old 05-23-06, 06:28 AM
SGT
Weekend Warrior
Garage is empty, add now
Trader Score: (0)
SGT's Avatar
Send a message via AIM to SGT
Default Disable VSC/TRAC
1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
2. Start the engine.
3. Engage the parking brake.
4. Fully depress the brake pedal and then release.
5. Fully depress the brake pedal and then release.
6. Disengage the parking brake.
7. Fully depress and hold down the brake pedal.
8. Engage the parking brake, the disengage it (while holding down the brake pedal).
9. Engage the parking brake, the disengage it (while holding down the brake pedal).
10. Release the brake pedal.
11. Engage the parking brake.
12. Fully depress the brake pedal and then release.
13. Fully depress the brake pedal and then release.
* When the "Check VSC" icon is displayed in the multifunction display along with the "Trac-off" icon indicator, you'll know that you have successfully complete the procedure! Your car is transformed!
*** One the car is started you have 30 seconds to complete the process. With practice, the procedure can be completed in app. 15 seconds, unfortunately, must be repeated each time the car is switched off (all systems are returned back to normal).
__________________
http://www.clublexus.com/gallery/dat...img04135sd.jpg
2006 GS300 AWD . Blue Onyx Pearl/Black . 18" Tourmalines . Continental ContiExtremeContact . Tanabe NF210 . Xtreme 3000k HID Fog Lights . LED Parking Lights . VAIS SLI . Madico 35% Tint . 3M Clear Bra . K&N Air Filter . V1
SGT is offline   Reply With Quote
