Dueler H/T D687 for your RX? Think again.
If you need replacement tires for your RX, don't buy the OEM Bridgestone Dueler H/T D687.
I got them 3 months and 6,000 miles ago. They have worn from 10/32" to 8/32". At this rate, I can only put 18,000 miles on this set before tossing them. (I get rid of my tires at 4/32".) My previous Goodyear lasted 54,000 miles. My tires on other cars lasted anywhere from 60K to over 100K miles. All four tires wore evenly. The alignment is perfect.
On the other hand, the Dueler performs very well in just about all other areas: it brakes very well on dry, wet, or snowy surface. Extremely quiet and smooth. I could live with it if this tire can last 40K miles, but 18K is way too soon. It does have 60K pro-rated warranty, but still.
Super Moderator
Tire tread doesn't wear in a linear fashion. They wear faster the deeper the thread like when they are new. There is more uncontrolled tread squirm in the early wear. After the first couple of 32nds wear off, there is less squirm and somewhat improved wear. If you wanted longer tread life why didn't you purchase the Bridgestone Dueler H/L Alenza?
The OEM Goodyear has a treadwear rating of 260-460*.
The OEM Michelin has rating of 300-500*.
The Bridgestone Dueler H/T D687 has a rating of 300.
The Bridgestone Dueler H/L Alenza has a treadwear rating of 600.
(* varies depending on tire size.)
If you wanted a longer wearing tire then you should have chosen the Alenza which should last twice as long as the tire you chose.
This info is readily available on the TireRack.com website.
"Frankly, the wear, traction, and temperature index on the sidewall are as good as used toilet paper"
Do you still feel the same?
in case you need a refresher here is a link the the 687 vs. Cross Terrain discussion:
https://www.clublexus.com/forums/sho...cross+terrains
You may want to consider a set of Cross Terrains or other higher rated tires. BTW, I finally picked up my second set of CTs.
Super Moderator
Originally Posted by mikey00
Cross Terrains have tread wear rating of 700 and the 687's have a tread wear rating of 300. I get over 60k on a set of CTs and using your numbers 687s should last 24k, assuming discarding at 2/32". If I do the math, the tread wear rating looks like it is quite accurate. Here is what you had to say last time I mentioned tread wear rating:
"https://www.clublexus.com/forums/showthread.php?t=62949&page=2&pp=15&highlight=cross+terrains"
Originally Posted by Lexmex
The 235-70-16s like mine have a tread wear of 420 if I am not mistaken, but the ply in Mexico has two more layers, I think a nylon is one of them.
Super Moderator
In the US, 225 Cross Terrains have a tread wear rating of 700, while the 235s only have a tread wear rating of 420. That means a 225 CT should last 1.7 times as long as a 235 CT. I always thought the Mexican 235s had a better rating than the US, but maybe not.
Super Moderator
I would also highly suggest using nitrogen in place of air on any tires. I know Costco does this in the states (and now in Mexico). We have discussed it before on CL.
I do not keep my tire pressue even on all tires and sometimes adjust for speed when I am not participating in bracket racing.
BTW, I altered my signature below. The mods will just grow and I felt it was time to just simplify things.
The nitrogen is a nice benefit of using Costco. I first purchased tires there for price and didn't really expect much in the way of service. But after a couple sets of tires I find them excellent with ongoing tire service.
Just curious, how's the wear on your 235s?
Super Moderator
Originally Posted by obaid
michelins are the best people
Out of Warranty
I thought Michelins were the most durable tires and then I saw this. Some guy named Fred owns it. Look at those tires...WOW!
I would not put so-so handling CT on an SUV, even though it may last long. Again based on C/R rating. I put higher priority on safety. The D687 handles very well. I can't even feel the strong gust here in Colorado. With Goodyear Integrity, I used to be all over the road.
I hope C/R will test SUV tires for its Nov 2006 issue.
The H/L Alenza's smooth tread can't work in Colorado winter. And I live in a rather rural area where roads don't get plowed.
Read the November 2005 Consumer Reports on what they found about tire wear index.
I also hope CR tests SUV tires in its Nov issue. Looks like the last SUV tire test was Nov 04. I hope they use the 225 Cross Terrain this time and not the lower spec 235. Sometimes people form a quick but lasting opinion based on these tests without taking the time to research what is actually being tested.
