Are new Strut Mounts needed?
Old Feb 9, 2006 | 11:44 AM
TexasSC400's Avatar
TexasSC400
Default Are new Strut Mounts needed?
Hey Guys,
I'm having new Tokico Blues and Tanabe Coil Springs put on it my 1992 SC400. I think this is the first time its ever been done. One of the shops I'm getting quotes from to do the work is quoting new Strut Mounts. Do I really need new ones? I've heard I can reuse the original ones...or are mine possibly too old. How can I tell?
Old Feb 10, 2006 | 09:05 AM
TexasSC400's Avatar
TexasSC400
Default needing some help
Need a little help guys. I know someone has the answer...or resourceful comment.
Old Feb 10, 2006 | 11:14 AM
bmatsu's Avatar
bmatsu
Since your car is a 92, you might as well change the mounts, it can't hurt.
good luck
Old Feb 11, 2006 | 12:49 PM
hitsolid's Avatar
hitsolid
I had the same setup installed yesterday on my 93 SC300 (143k freeway miles). I got a look at the old strut mounts and I would recommend installing new ones. Not only for the potential of a better ride but also because the old ones have most likely cracked or broken and will not provide any protection to the new struts.
Old Feb 12, 2006 | 07:42 PM
stevechumo's Avatar
stevechumo
Originally Posted by TexasSC400
Hey Guys,
Did you mean the rubber strut mounts or the metal strut mounts? If the rubber mounts got worn and cracked, you can use hard silicon, soft gasket maker, or rubber sealant to fix them like in original shape and let them dry overnight. The job is easy and about $5. If the metal mounts with 3 studs on each mount that bolt to the chassis went bad, it's hardly the case. Mine 95 SC has 148,000 miles on them with no problem. However, I believe the KYB has each metal mount for around $45. Or the problem could be the strut bushings that are broken.
E36M3
Mar 28, 2013 02:14 PM
4evDev
Oct 6, 2012 08:24 PM
dkls400
Aug 23, 2010 08:38 PM
qmanlexus2
Jan 24, 2009 10:55 PM
TRoyals14
Dec 20, 2005 10:00 AM
