rear struts interchangeable ?
Old Dec 12, 2005 | 11:39 AM
patyz's Avatar
patyz
Default rear struts interchangeable ?
stupid Question ,Can the rear struts on a sc300 be switched? (This is the whole unit)
need to replace left rear and I have an extra right rear all setup
thanks
Old Dec 13, 2005 | 09:14 AM
VQT's Avatar
VQT
I don't see anything wrong with that, they are exactly the same. Just make sure you have it line up correctly for the three holes on top and the bottom bracket of the strud fit over the control arm slot.
Old Dec 28, 2005 | 02:58 AM
rscott's Avatar
rscott
its not too advisable for more that a quick fix. when you use a used shock (any used shock for that matter) if its not installed exactly the same as before it shifts the stress points from one part of the shock to the other. if the shock was never disassembled you might be okay but either way it will probably have a reduced life.
caddy3646
Jul 9, 2018 10:59 AM
nkt001
Jul 4, 2018 04:53 AM
dante1616
Dec 10, 2011 08:07 AM
hypervish
RX - 1st Gen (1999-2003)
May 10, 2011 06:39 AM
