Transmission selector problem: Hard to shift out of Park
Old 07-25-05, 03:05 PM
MellonC00
MellonC00's Avatar
Default Transmission selector problem: Hard to shift out of Park
Need some tech help here.
Shifting out of Park is getting harder and harder for some reason. Sometime it even makes a loud thunk when I shift out of park. Depressing the brake all the way to floor makes this easier but don't recall my transmission selector being this hard to shift. It's worse when the car is parked on a downhill.
Just on a side note, my transmission fluid was pretty dark - close to black. So, I've been doing drain and fills for the last 2 oil changes - fearing that a tranny flush might get some particle lodged in the tranny somewhere. This, by the way, didn't provide any relief to my shifting out of park problem.
Any idea? Thank you for your suggestions.
Old 07-25-05, 03:24 PM
Lil4X
Out of Warranty
Lil4X's Avatar
IMHO it might be more useful to do a complete flush on the transmission fluid. If there's a particle of something in there, it will find a place to lodge on its own. At least give it an opportunity to flush out. Transmission needs a new filter too. You might have a good mechanic who is familiar with Lexus or Toyota transmissions take a look . . . your ATF should NOT be black - that indicates a problem may be in your future.
To alleviate your parking problem, when parking on a hill, set the e-brake before shifting into Park. That will help prevent the vehicle from rolling and putting a load on the parking pawl in the transmission, making it difficult to get OUT of Park.
OK, experts, let's give him some help here!
Old 07-25-05, 05:51 PM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Not that it will solve your problem, but use the auxillary (foot-brake/parking-brake) to release the load on transmisson when parked on incline.
Salim
Old 07-25-05, 06:37 PM
koolaidman
koolaidman's Avatar
how bout using the parking break when u park on an uphil. whats ur rmps at when u shift into gear
Old 07-26-05, 07:47 PM
LexusSexus
LexusSexus's Avatar
If you're still under your drivetrain warranty make sure you get it in for service. My experience with Lexus warranty service has been phenomenal. At least get the problem on the books
Old 07-28-05, 10:39 AM
MellonC00
MellonC00's Avatar
Thanks for your suggestion. I doubt that I have to change the tranny oil filter. Changing a tranny oil filter is highly unusual. I've never seen it done.
What is an E-brake? RX was never equipped with such a thing. Parking brake is available and I use it diligently.
Maybe I shouldn't have mentioned the transmission oil color. The transmission really isn't the fault here, IMO. The problem is the selector itself. Anyone ever run into this?
Old 07-28-05, 10:50 AM
mmahamm
mmahamm's Avatar
E-brake = emergency brake = parking brake. Just another way of saying it.
Maybe an issue with the interlock between the (regular) brake pedal and the shifter. The interlock prevents you from shifting out of park unless your foot is on the brake, but if there is a problem there, it may be sticking somewhat.
Also, don't dismiss the transmission as the culprit. The shift lever is connected to the transmission, and it very well may be that a problem in the transmission is causing the difficulty in shifting from Park.
Old 07-28-05, 01:25 PM
MellonC00
MellonC00's Avatar
I see. I was confusing some E-brake function from latest sports cars.... Thanks for the clarification.
Your second comment worries me. I think I may even have to go to the dealer if I don't hear back any first hand comments.
Old 07-28-05, 07:45 PM
salimshah
Forum Moderator
salimshah's Avatar
Just for clarity there is a procedure to follow applying and relasing the auxillary brake to releive the transmission ..
Stopping:
Apply Aux. brake.
Shift to park.
Giddyup:
Move out of Park.
Release the Aux brake.
If you apply the Aux brake after transmission is in Park, the strain is already built-up.
Similarly releasing the Aux brake with the trans in Park trasfer the strain.
*** This only helps when parked on an incline. If the problem is also on level surfaces, the above may not help you.
Salim
Old 07-29-05, 03:20 AM
CK6Speed
CK6Speed's Avatar
How many miles are on your RX? While this is just my guess, it could be a worn or broken transmission mount. The hard shifting out of park is one symtom of that, but also could be for many others as stated above. Broken transmission mounts are somewhat common on cars as they get up there in miles. I can start as early 60K miles. Yes, even Lexus is prone to this as my SC400 needs new trans mounts when I got it from the previous owner.
Old 08-05-05, 10:56 AM
MellonC00
MellonC00's Avatar
How much did the new mount cost you?
lserlohn
41
06-06-16 05:45 PM
Lexus813
15
10-13-13 07:44 AM
KennedyN
09-04-13 11:09 AM
gsedan400
Performance
01-03-11 09:57 AM
xcamryman
12-04-06 02:31 PM
Quick Reply: Transmission selector problem: Hard to shift out of Park
