DIY: A/C compressor removal and installation
Old 07-15-05, 05:30 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Default DIY: A/C compressor removal and installation
Well, I could have paid someone to do this for me, but I figured I'd better DIY so I could share pics and info for anyone wanting to do this. (the things I do for you)
So here's a short writeup with pics.
1- remove the battery and tray
2- remove the main belt from the engine by loosening the tensioner.
3- disconnect the main A/C electrical harness and 2 coolant lines
4- go under the car and remove the ground wire bolt and harness
5- (optional) remove the oil filter (you'll thank me later when you go to remove the lower bolt)
6- remove the 3 bolts that hold the compressor in. I prefer to do it from the top front, then top back, then bottom.
7- slide the A/C compressor forward and rotate it for best maneuverability while pulling it out the top of the engine bay.
*Note- there is a small "z" bracket on the ground cable bolt that connects it to the compressor. Make sure you re-install it.
Reverse the directions for re-installation.
Old 07-15-05, 05:32 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 07-15-05, 05:33 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This is for an SC400, but hopefully the 300 will not differ much, or any.
Old 07-15-05, 09:23 PM
/Aerostar\
/Aerostar\'s Avatar
Nice writeup, but please dont tell me I see a Fram oil filter in there? For shame OLT, for shame haha
Old 07-15-05, 09:24 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Yup I did this on my hooptie. It's just used for testing nowadays. It logged 45 miles in the last 5 months I drive my sandstone one as a daily.
Old 07-15-05, 09:25 PM
happypanda
happypanda's Avatar
wats wrong with fram?
Old 07-15-05, 09:34 PM
koolaidman
koolaidman's Avatar
looks like u missed the part of evac the system.
Old 07-15-05, 10:21 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Nothing had to be done other than what I posted.
Old 07-16-05, 12:09 PM
TMaxxTim
TMaxxTim's Avatar
So you just charged it up with some r134a and it's been good as new since?
On my SC3 I can't pressurize the a/c system as much as it should be since by doing that the a/c compressor just engages and then disengages every 10-20sec.
The other thing I've noticed is after a drive at a high rpm for 1-2 min (5000+) or a drive at 85 for awhile I'll smell a burning inside my engine, already replaced the waterpump so I think the compressor clutch/compressor itself has to do with that. What caused you to replace yours, just loss of r134a?
Old 07-16-05, 12:51 PM
FloridaSC
FloridaSC's Avatar
Whats the seceret to getting to the rear upper bolt? My cars been apart for ever because I can't get the AC compressor off to change the water pump.
I boght a 14mm (built-in) universal socket, but have not had time to use it. I can't seem to get a socket up there. Are you accessing from the top or bottom?
Old 07-16-05, 01:05 PM
TMaxxTim
TMaxxTim's Avatar
Do you have a 400 or 300, because on the 300 you don't have to take off the a/c compressor to get to the waterpump.
Old 07-16-05, 02:23 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
No way dude. I can't stand 134. Doesn't blow cold enough. I use only good old ice cold r12 freon. $65 a pound and worth every dime. I just had all 5 cars charged up with 3 lbs per car...... guess what that cost.
My local Maxi muffler charges r12 systems
Old 07-16-05, 02:26 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This should be good avice on both the 300 and 400. If you have a 4 inch extension it will get in there, but not bump the frame on the ratchet end.
Old 07-16-05, 05:20 PM
Nomis
Nomis's Avatar
OLT - if you get an under-engine pan your whole engine bay will stay much cleaner - IMHO.
Old 07-16-05, 06:04 PM
Kaiser
Kaiser's Avatar
Doesn't look much like the 300. Good thing you didn't get it from me.
Quick Reply: DIY: A/C compressor removal and installation
