Quote:
Originally Posted by looknow12
Rockville,
On the GS430 w/VDIM, do you notice any difference in the abruptness of the traction control cutting power? My 2000 GS400 (even my GX470 will do this, not as bad though) would abruptly cut power when traction was lost making it very slow to accelerate. I wondered if the VDIM computer helps the traction control system as well.
In my mind, there's no reason power cannot be dynamically reduced to the slipping rear wheel and then again quickly released when traction has returned. We need faster responses from the traction control CU.
Our dealership is on a busy six lane divided road that the posted speed is a joke. If you make a right turn on red you will have trucks and cars bearing down on you at 50MPH plus. The traction control can kick on and the power will "sag" and you are left holding the bag helplessly. The VDIM won't even let the wheel spin much if traction is a problem. It is snowing right now and I'm going to wait for it to stick and try out the VDIM some more. It is addictive. It reacts early and smoothly to abrupt inputs whether throttle or steering. I think it is an equivalent safety advance as ABS which freed us from pumping our brakes manually. You don't get that out of control feeling in slick conditions that we did on the Gen. 2 GS430. This is all while comparing a 17" wheel on the Gen.2 with an 18" std. run flat on the Gen. 3. Put some studs on it and it would be fun to drive on a frozen lake....
