2006 Hummer H1 Alpha
Old Oct 28, 2004 | 01:07 AM
Davtown's Avatar
Davtown
CL Folding 10,000
Lightbulb 2006 Hummer H1 Alpha
The 2006 H1 Alpha, featuring GM’s Duramax 6600 diesel engine, takes HUMMER performance to its ultimate extension and represents the single greatest advance in the 14-year history of the original HUMMER.
Arriving in dealerships in early 2005, the H1 Alpha delivers more power, more torque, and enhanced on- and off-road capability, with significantly improved fuel economy. GM’s award-winning Duramax 6600 (6.6-liter) turbo-diesel engine and Allison 1000 five-speed automatic transmission give the H1 Alpha dramatic performance improvements and add to the H1’s legendary off-road capabilities.
H1 Alpha is the first in HUMMER’s new performance series. “Alpha represents HUMMER performance taken to its ultimate extension,” said Susan Docherty, HUMMER general manager. “That means improving HUMMER’s already-unmatched off-road capability, along with enhancements to fuel efficiency and driving comfort on the road. As the original HUMMER, the H1 is the perfect vehicle to mark the start of the Alpha series.”
As was the case for previous H1s, the 2006 H1 Alpha will be offered in both Open Top and Wagon models. The Duramax 6600 replaces the previous 6.5-liter Optimizer Turbo-Diesel, which will continue on as the power plant for the military HUMVEE, the vehicle on which the H1 is based. All commercial H1s produced for the 2006 model year will be H1 Alpha models. H1s used for fleet sales will use the Optimizer engine.
H1 Alpha marks another important aspect of HUMMER’s ongoing growth, as the brand introduces new models and makes significant improvements to existing models. The H2 SUT, a new version of the H2 featuring a pickup-style cargo bed, began sales in the summer of 2004. The all-new H3, packing authentic HUMMER design and capability into a smaller and more fuel-efficient vehicle, arrives at dealerships in the spring of 2005.
Alpha performance: best-ever H1
H1 Alpha is the highest performing H1 ever, with more horsepower, more torque and better fuel economy. The Duramax 6600 delivers 300 horsepower at 3000 rpm, a 46 percent increase over previous H1s equipped with the 6.5-liter Optimizer Turbo-Diesel. Peak torque is a massive 520 lb.-ft. at 1500 rpm, an increase of 18 percent.
The H1 Alpha’s increased power makes its already-extreme off-road crawling and climbing ability more potent. On the road, the new powertrain provides smoother, quieter and more comfortable operation, with better acceleration. Zero-to-60 acceleration improves by a full three seconds to 13.5 seconds, respectable for a truck that is an off-road performer without peer.
At the same time, fuel economy of the H1 also improves. Preliminary testing indicates significantly improved fuel economy. A revised fuel system also increases capacity of the H1’s two on-board tanks to 51.5 gallons, 9.5 gallons more than previous H1s. The increased tank capacity combines with the efficiency of the Duramax to raise cruising range from 400 miles to an estimated 570 miles between fill-ups.
The Allison 1000 transmission is an important aspect of the H1 Alpha’s comprehensive performance improvements. This five-speed automatic from Allison Transmission is extremely stout and durable as it is utilized in medium- and heavy-duty commercial trucks. The Allison 1000 features a Tow/Haul mode that adjusts shift patterns for optimal performance when the vehicle is towing or carrying heavy loads. The Allison unit aids the H1 in severe maneuvers with features such as improved drivetrain braking and a crawl ratio of 45:1, an increase of 22 percent.
With the improved power and efficiency of the H1 Alpha comes an increase in towing capacity. Gross Combined Weight Rating (the sum of vehicle, maximum cargo and towing capacities) increases 2,000 pounds, to 17,300 pounds.
Several other areas of the H1 Alpha also have been enhanced, in addition to the drivetrain. Brake rotors are larger, going from 10.7 inches to 12 inches in diameter. The half-shafts on each axle and the steering gear have all been bolstered to better manage the Alpha’s increased capabilities. One of the H1’s unique suspension features from its outset are the geared hubs at each wheel that contribute to the truck’s incredible crawling and climbing ability. These have been redesigned for the H1 Alpha and feature a helical-cut gear set. This new design improves gear engagement, which reduces both the noise and rocking motion during deceleration and stopping maneuvers.
To accommodate the new dimensions of the Duramax 6600 and Allison 1000, the body of the H1 Alpha is positioned 2 inches higher than the previous H1. This provides slightly more clearance for the body panels from the wheels and from potential obstacles on trails.
Alpha is about performance, more than style. However, there are a few visual enhancements to the H1 Alpha. The new Alpha shield logo appears on a badge just above the rear bumper. A Duramax badge adorns the front driver’s side corner of the body, surrounded by a redesigned brush guard. The wheels have also been freshened, featuring a new, brighter finish.
On the inside, the H1 Alpha features the new interior that debuted on the 2004 H1. Those improvements included aniline leather seats, revised controls, and more luxurious surfaces throughout.
source media.gm.com
Old Oct 28, 2004 | 01:11 AM
Davtown's Avatar
Davtown
CL Folding 10,000
Thumbs up Looks good from here
6.6 Liter Duramax Turbodiesel and an Allison 1000 Transmission.... works for me.
Althougth I've loathed H2's since the day the came out, I've always had a soft spot for the original H1 - years before the H2 was even a concept.
This H1 gets in my book.
Old Oct 28, 2004 | 02:22 AM
BLexACK LS's Avatar
BLexACK LS
I am in the same boat as you i love the old ones, all real deal no B.S. gotta love em.
Old Oct 28, 2004 | 08:21 AM
CleanSC's Avatar
CleanSC
The H1 is and always will be a bad-*** machine. There is nothing on the road like it and anyone not familiar with this machine's capabilities and technologies should really read up on it. It's fascinating.
The brakes are not even at the wheels. They are on the center diff tucked into the sheilded underbody area to protect them. There's a mini gearbox at each hub for torque managment. There's a central tire inflation system that lets you raise or lower tire pressure to all four tires via an on-board compressor WHILE YOU ARE DRIVING IT (there's a button on the dash).
Very cool stuff indeed.
This new hummer H1 will surely be way over 100k so don't forget to consider a Porsche, Aston Martin, new house, or a pair of LS430's.
Old Oct 28, 2004 | 11:42 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Does anyone else find it humerous that 11 MPG is considered a major revision for the H1?
Old Oct 28, 2004 | 11:58 AM
CleanSC's Avatar
CleanSC
With an SC that gets 16mpg, I'm not gonna complain. lol
Remember this thing weighs almost 3 tons (you read that right, just under 8,000 pounds).
Mileage will suck with anything that big no matter what.
With that said, anyone that uses this as a commuter vehicle should be stoned (with rocks, you potheads ). Unfortunately in this country people are less than efficient and love to drive their multi-ton car crushers 30 miles a day to the office. Which by the way, puts the rest of us at risk.
If an H1 were to take on a Scion xA or Mini at an intersection, I can gaurantee you which one will have the grieving family.
Old Oct 28, 2004 | 12:06 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Lol the H1 wouldnt even know he hit a car until he gets home and sees a lil Mini attached to his bumper.
Old Oct 28, 2004 | 12:21 PM
CleanSC's Avatar
CleanSC
They should install bumper cams as standard equipment to alert owners of exactly this.
Should keep the Mini's, school children, deer, toll booth operators, dogs, mailboxes and other debris from piling up in the grille.
Lextranny
Sep 2, 2005 01:13 PM
Gojirra99
Aug 5, 2005 07:51 AM
LexFather
Jul 28, 2005 10:12 PM
LexFather
May 26, 2005 08:55 PM
LexFather
Jan 11, 2005 01:55 PM
